EOS R6 Mark II Face Detection AF Not Present
Do you have any idea as to why the face detection AF is not present in R6 Mark II?
Hi,I'm shooting a job where I have to upload the pictures from my camera to an ftp server. I was sharing the network on my phone to connect my cameras to the ftp via wifi, which worked totally fine. However, a part of the job is shot in an arena fill...
I have a Canon EOS R6 Mark II, and I have successfully connected it to an external monitor/TV screen via HDMI-micro cable. The only issue is that the image on the monitor/TV is reversed. I am self-taping, so if I exit the frame right it shows up exit...
I recently am not able to connect to a monitor or tv through HDMI cable for video out display. It was working fine on a previous monitor, but upon switching the monitor, now the camera won’t connect to any of the HDMI out display devices. My wifi set...
From the The Online Photographer which took it from a Canon Marketing site:https://theonlinephotographer.typepad.com/the_online_photographer/2023/02/middle-class-cameras.html Untitled.jpg
Simplicity and Power. The Canon EOS R8 is a full-frame camera that takes your potential wherever you want it to go. Learn more about the EOS R8: https://canon.us/3HGxoH6
For the canon r5c the camera has dual base iso. In photography would it be ideal to use those same base iso. Does it apply to photos or only video??
I am trying to figure out flash sync setup for R5 and pocketwizard triggered monolights. All of the info I find is regarding setup for external Canon speedlights. Anyone firing monolights from an R5? I am getting a dark edge down the right which tell...
I use a 5DM4. I'm looking to get some extra memory cards. Since I shoot a lot of time lapse videos, I need a pretty high read/write speed. I currently use SanDisk Extreme Pro CF card, which writes at 160. I see CF type B cards with transfer rates of ...
I work for a large global company as a motion designer, but also do a lot of videography and photography around our offices. I have 3 x GH5 II's for my filming purposes but need a better photography camera. I currently use a 60D that was left by the ...
I've just bought a canon 450d. It definitely works with a 16gb SD card I had in another device at home.Need to buy an SD card for this camera.Most stores I've come across don't have anything smaller than 64gb micro SD cards with an SD card adapter.A ...
Hi All,I shoot mostly stills for real estate, architecture, kitchen remodels etc. My 5D MkIV is excellent for this.I am starting to shoot video and find my 5DmkIV which sits on a DJI Ronin RS3 very heavy.What lighter body would you recommend for vide...
So i bought an old A1 camera cheap from a cousin and it seems to be near pristine condition if it wasnt for the fact that the winding lever doesn't move past the halfway point. I have new batteries, new film, tried the double exposure and it doesn't ...
Hello,I'm new to the group and hoping someone can help me.I have the Canon R6, I want to update the firmware.There is no option for Mac OS Ventura 13.1.This is a fairly new laptop and OS. How do I update the firmware?I appreciate the help.Thank you!K...
I'm having a problem with vignette/banding on one side of my pics when using studio strobes. At first I thought this might be caused by exceeding the shutter speed max resulting in banding from the curtain but the attached samples were all shot at 1/...
| Subject | Author | Posted |
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-24-2026 10:39 AM | ||
| 04-22-2026 11:08 AM | ||
| 12-18-2025 01:20 PM |
