12-14-2021 10:43 AM
I'm using my R5 to take raw images for time-lapse video. I'd like to use the camera's internal intervalometer, but its counter is limited to two digits, or a maximum of 99 images. Is there a reason for this limit? Having a 3, or even 4 digit counter would be most helpful.
Yes, I know I can use an external intervalometer, but if the intervalometer feature has been designed into the camera it seems odd to have this rather arbitrary limitation.
12-14-2021 10:56 AM
We are not Canon, so we cannot say. I know of no way to effectively report this kind of feature request, either, but I suppose, this forum is as good as any.
12-14-2021 11:10 AM
To provide product feedback to Canon, go to Canon USA, scroll to the bottom and click on "Feeback" (under the "Contact" section of links). Then choose "Product".
12-14-2021 06:00 PM
Follow the wise advice given above. Contact Canon, and refer to your User Manual. I would venture a guess that if you set the count to “00”, the camera will keep taking shots until the battery dies on you.
12-15-2021 07:49 AM
Thanks for the comments. I've sent feedback to Canon as suggested by rs-eos, but I'm not really expecting to hear back from them. I've not tried setting the counter to '00' for continuous interval shooting, but I'll give that a try as well. For now, it's back to my external intervalometer.
Oh, and yes, I've read the Advanced Manual - all 927 pages 🙄, but I'm always open to suggestions.
Thanks again.
John
EOS R5, 24-105 f4L, 15-35 f2.8L, 100 f2.8L, EF-RF Control Ring converter
EOS 5DIII, 24-105 f4L, 100-400 f/4.5-5.6L IS II, 70-200 f4L, 600EX-RT
12-15-2021 08:31 AM
Well you missed something:
12-15-2021 09:47 AM
kvbarkley, it's not clear what you're pointing out to me. I do see that '00' gives continuous interval shooting, but I still don't see a way to have the sequence stop at more than 99 shots. My needs typically call for 400-800 unattended shots. I'd rather not have the camera continuing shooting forever.
But thanks for your comment.
John
EOS R5, 24-105 f4L, 15-35 f2.8L, 100 f2.8L, EF-RF Control Ring converter, 600EX-RT, GP-E2,
EOS 5DIII, 24-105 f4L, 100-400 f/4.5-5.6L IS II, 70-200 f4L IS, 500D Close-up lens
12-16-2021 01:18 PM
I don’t think I was clear about setting the interval to “00”. What I mean is to set the total number of interval shots to “00”. That should take you past the 99 shot limitation.
