12-14-2021 12:41 PM
Shooting large jpegs about 13 per shot, after I got home and put them on the computer noticed that about half way through my shoot the the megapixels were cut to half the original size then halved again to about 3.5 They stayed that way for the rest of the shoot. Checked my setting and all were the same. Shot some more today and they are back to 13. Any ideas?
12-14-2021 02:42 PM
The sizes are mere estimates. If you have large areas of the same color the images can be compressed much smaller. I you shoot at high ISO's the noise makes the files less compressible leading to larger files.
12-14-2021 02:45 PM
At first I though the original poster was speaking to the file sizes as well (which as kvbarkley states above) can vary greatly.
But I believe the question was about resolution; as if the camera decided on its own to switch to say medium size, then later, small size. I don't know what would cause that.
12-14-2021 02:46 PM
Thanks Kv. The back ground is different. I think that did make a difference.
12-15-2021 11:12 AM
@TONY1900 wrote:Shooting large jpegs ...
Try using Raw. You will bypass the in camera compression routine.
12-15-2021 11:35 AM
I was shooting in raw and j-peg. Raw was cut in half also. The background got a more solid color when pixel dropped. I believe this is why the pixel were so low.
Thanks for the input Biggs
12-15-2021 11:49 AM
I'm still confused. You're mentioning that pixels are being dropped. What does that mean? Are you speaking about the file sizes (bytes), or image dimensions (pixels; width & height)?
12-15-2021 12:33 PM
If RAWS use compression, it is lossless.
12-15-2021 01:16 PM
File size. A large jpeg is say 12.0 per. As my background changed to a much blacker setting the file size was cut in half because to about 4.5. Same in Raw. After doing some research and some guidance from Y'all I got it figured out.
Just never noticed it before. Only been shooting for 30 some odd years. Ha
12-16-2021 10:41 AM
