EOS R6 Mark III Firmware Request: Allow Manual (M) Exposure in PHOTO Mode When S&F Is Selected
caiocarvalhopho
I could change from Slow Motion High Frame Rate Video with one movement only with my old R6 Mk2 but now i need to change two dials and this is ruining my workflow for work...
I would like to request a firmware update for the EOS R6 Mark III that allows Manual (M) exposure in PHOTO mode when the Mode Dial is set to S&F (Slow & Fast Motion).
I am a sports photographer who frequently switches between still photography and slow-motion video during running events.
My preferred workflow is:
  • Mode Dial: S&F
  • PHOTO/VIDEO switch → PHOTO: Manual (M) exposure for still photography
  • PHOTO/VIDEO switch → VIDEO: S&F video with my configured frame rate and manual exposure
This would allow me to switch between still photography and slow-motion video using only the PHOTO/VIDEO switch, without having to change the Mode Dial.
Currently, when the Mode Dial is set to S&F and the PHOTO/VIDEO switch is set to PHOTO, the camera uses Program AE (P) instead of allowing Manual (M) exposure.
This is particularly inconvenient for sports photography because I normally shoot in Manual mode with a specific shutter speed, aperture and ISO. Having to change the Mode Dial every time I want to switch to slow-motion video adds an unnecessary step and can cause missed moments.
I would like to request that Canon add an option in a future firmware update, for example:
S&F Photo Exposure: P / M
This could simply be an optional setting, so users who prefer the current behavior could continue using P, while photographers who need a manual still-photo workflow could select M.
This would make the PHOTO/VIDEO switch much more useful for photographers who alternate between stills and S&F video during the same event.
The workflow was also more convenient on my EOS R6 Mark II, so I would appreciate it if Canon could consider restoring this flexibility on the R6 Mark III.
Thank you, Canon, for considering this firmware feature request.
Personally, I have never used it. I do not know whether or not it asks for your email or contact info. What I do know for certain is that you should not expect a direct response.
I have seen many posts by.forum members complaining about the lack of a response.  I don’t think that feedback to users was ever intended.
It seems to work like an old wooden suggestion box mounted on a wall. You drop a written note in a slot in the top, and that would be it.
3 REPLIES 3
Waddizzle
“ Thank you, Canon, for considering this firmware feature request. “
These forums are a social media platform. If you want to make a product request or suggestion, then there is a “Feedback” link located st the bottom of the Canon USA home page.
caiocarvalhopho
Thanks found it... its very hidden
