06-22-2019 07:10 PM
Today when I was out taking pictures, I put my display screen back but it was all upside down. The text is upside down and the display pictures as well. I checked my menu and the auto rotate is set to on. I turned it off to see if it would fix it and it did not work. I also powered off and took out the battery and it did not fix it. Does anyone have any ideas?
Thanks!
06-22-2019 07:19 PM
What camera model do you have?
In the meantime go to your settings and perform a reset to defaults for starters
06-22-2019 08:34 PM
06-22-2019 08:47 PM
Auto rotate only comes into play when you are taking shots with the camera in a vertical position so that the displayed image will be vertical too so I do not think that is your problem.
06-22-2019 08:51 PM
06-22-2019 09:05 PM
Is the image upside down when the screen is pulled out or only when it is folded back into the camera?
06-23-2019 12:37 AM
06-23-2019 10:14 AM
It could be your screen orientation sensor has failed. There is a youtube video for the 60D camera which shows another possible problem and solution, I don't know if it applies to the T6 but it looks like a simple fix.https://www.youtube.com/watch?v=6DPBDk4ZVJU
06-23-2019 03:08 PM
06-23-2019 03:24 PM
That is good news!
