R5/EF Adapter compatibility
drodow
Hello, I have the EOS R5 with a Canon Mount EF Adapter and a 70-300mm 5.6L IS USM lens. I need to know it the Canon 1.4x extender will work with this configuration?  I hope so otherwise I will have to sell the 300 and buy the 100-400.
Thank you for your help.
2 ACCEPTED SOLUTIONS
Tronhard
VIP
VIP
The EF 70-300L is NOT compatible with Canon's teleconverters - they will physically not fit on this lens.
If you want to get an extended reach, then the RF100-500L is a brilliant choice for the R5 (at a cost), but if you want to stick with EF lenses, then I can recommend the 100-400MkII or the Sigma 150-600c lenses.
However, given that the R5 has 45MP,  it might be worth keeping your EF 70-300L and simply crop - it IS an excellent lens!
To demonstrate the potential of a higher MP sensor with this lens, this is the 70-300L with the quite unforgiving Canon EOS 5DsR, which has the cancelled AA filter and at 52MP shows any flaw in the lens or its use.  Of course, to post here, the images have had to be SERIOUSLY downgraded, but you should get the idea.
As taken: Helicopter ULR.jpgHelicopter ULR.jpg
After cropping:
cheers, TREVOR
FloridaDrafter
@drodow wrote:
"Hello, I have the EOS R5 with a Canon Mount EF Adapter and a 70-300mm 5.6L IS USM lens. I need to know it the Canon 1.4x extender will work with this configuration?  I hope so otherwise I will have to sell the 300 and buy the 100-400.
Thank you for your help."
As mentioned, the extender won't physically fit the EF 70-300mm L f/4-5.6 IS USM II, so IMO if you are going to spring for the EF 100-400mm L f/4.5-5.6 IS USM II, I would go for the RF 100-500mm L f/4.5-7.1 IS USM. I agree with Trevor that the EF 70-300L II is a great lens. I have used it on all of my bodies, from an XSi, through various Rebels to the 7D mark II, 5D mark IV and now the R5 and R6. You will get good resolution with it on the R5 so you can crop in, if need be. I also have the EF 100-400mm L II and a 1.4X extender. I really don't care for that combo as it just doesn't give me the res I want, plus you are giving up a stop at 400mm. Like you, I shoot birds, more times than not, tiny birds like warblers. The EF 100-400mm L II and ring adapter on the R5 works great and if I get close, cropping still leaves plenty of detail and I could get a 10" print when needed.
Although I like the EF 100-400mm L II, I still bought the RF 100-500mm L for the R5 and let the EF 100-400mm L II live on the 5D IV. I like the RF glass and although I can only see a slight improvement in IQ in the RF L over the EF L glass I own, there is more to it then that, like they are generally lighter, designed better (according to specs), and I like the redesigned hood of the RF 100-500 L, I know, small thing, but it is what it is. Although EF glass works fine on the R systems, I think the RF glass is the way to go if you can afford it, it just feels right.
Tufted Titmouse - R5 and RF 100-500 L at 35 feet.
Ruby-crowned Kinglet - R5 and RF 100-500 L at 40 feet. These birds are under 3" and a pain to shoot. They hardly ever sit still and rarely come out in the open.
Newton
24 REPLIES 24
kvbarkley
Are you talking an RF100-400? Whether the extender works or not, it is probably best to have an RF lens.
I hadn't thought that far about it yet.  I'd have to research the advantages as I really wanted the extender for bird photography, more is better.   With the price of the extender plus the EF 100-400, I'm not that far away from the price of the RF 100-500.  Thanks
Tronhard
VIP
VIP
After cropping:
cheers, TREVOR
FloridaDrafter
Newton
This is potentially misleading -- an RF lens will NOT work on an EF extender, just as you can't adapt an RF lens to an EF body.
There is an RF extender, and like the EF extender, it has a limited list of lenses it works with -- see the manual for the list.  It's a VERY short list, and the 100-400 is NOT on the list; the 100-500 is.  See the manual here:
https://www.canon.co.uk/support/consumer_products/products/cameras/rf-lenses/extender-rf-1.4x.html?t...
Of course a longer lens *instead* of a converter should be fine.
jrhoffman75
The issue with the 70-300 lens is that for lengths shorter than around 250mm the rear element of the lens extends beyond the mount and will hit the extender. If you are willing to accept essentially a fixed 420mm lens then it will work.
John,  I have the EF 70-300L  lens and both of the Canon MkIII extenders and literally just tried to attach them to the EF70-300L.  According to my experience in doing so, the rear element of the 70-300L has very little travel and the 1.4x MkIII extender cannot be attached at any focal length, while the 2.0x MkIII extender does but only very close to the 300mm FL, so your answer appears to be only partly correct. Furthermore, being a 2x unit, the lens loses 2 f-stops, rendering an effective f-stop of f/11.
However, I would not suggest using an extender at all as the very limited benefit of attaching an extender is arguably not worth the risk of damage to the rear element is IMHO.  Canon have not recommended using any extenders with this unit.
If there is a 3rd party extender that does work, and you are basing your recommendation on this, it might be helpful to be specific.
cheers, TREVOR
This is what was reported in the-digital-picture.com
Then, in a major firmware updateannouncement for the Canon EOS-1D X, Canon included the 70-300 L and Canon EF 1.4x III Extender combo on a compatibility list.
Intrigued, I did more experimenting. What I learned is that the 70-300 L's rear element retracts into the lens far enough that, at about 250mm, there is enough clearance for Canon extenders to mount.
The available with-1.4x focal length range is about 350-420mm and 500-600mm with the 2x installed. Zooming out wider than the 250mm-or-so zoom ring mark results in a physical bump inside the lens. I'm guessing that it is the rubber around the edge of the extender element contacts the rear 70-300 L lens element or its barrel. I do not recommend mounting this combination due to potential damage to the lens.
I of course felt the need to try out these unsupported combinations. My solution to the damage risk issue was to Gaffer Tape the lens zoom ring to lock it at the 300mm mark while using extenders.
Perhaps it is sample variation.
@jrhoffman75 wrote:
"The issue with the 70-300 lens is that for lengths shorter than around 250mm the rear element of the lens extends beyond the mount and will hit the extender. If you are willing to accept essentially a fixed 420mm lens then it will work."
That's pretty cool, John! I never thought to extend the EF 70-300 to 300 to attach the EF 1.4x III. I didn't realize that the rear element moves during zoom.
Newton
