Desktop Inkjet Printers
ip 8500 wrong washed out colors
Hello to you all!I have a pixma ip 8500 printer which started to print washed out colors. It happens even when printing text documents. I have  cleaned the print head and deep cleaned it. Then I cleaned the print head with warm water to unclogg it bu...
piki by Apprentice
  • 1708 Views
G4210 works with MAC but not Microsoft
Hi, Strange behavior.  The G4210 prints fine from MAC but on all of the Microsoft OS computers, the prints are fuzzy or alignment is off.   I have updated the drivers.  All up to date.  The maintenance test pages print ok from the printer itself.  Do...
Setting up TS3520 All in One Wireless Printer
Hi everyone! I just wanted to share how I was able to set up the wireless abilities on the Canon TS3520. I did do a search on the forums and came up 404. Canon website and information on setting up the TS3520 left me frustrated and confused. After sp...
Resolved! PG-210 XL cartridge is too big for IP2702
Hey. I bought an ink cartridge from Amazon because I ran out of ink. I bought the same cartridge model as always, the PG-210 XL. Printer model is the IP2702. However, this is the first time but the ink cartridge is too big to fit. Not sure why? On th...
php111 by Contributor
  • 1861 Views
Mac vs. Canon
I have MacBook Pro and canon pixma ts9520.  I cannot print photos from my MacBook.  Canon and Mac say it's each other's issues.  Regardless after several hours on calls no resolution.  My Mac version is Big Sur 11.4. I've tried everything.  I can pri...
Eferna by Apprentice
  • 1292 Views
Pixma iP110 stopped printing color Mac
My Pixma iP110 stopped printing color on both my IMac and PowerBook. It still prints black and white, and the supply utility shows that it still has color ink. My HP printer is still printing color and black and white. I've reset the printers twice t...
BCammack by Apprentice
  • 4910 Views
Support Error Code 1681
Error says I have more than one of the same colored ink cassettes installed.  This is not the case!  All ink cassettes are as they should be.  But my small black # 251 is highlighted as the problem.  All of the cassettes are newly replaced!
MeDo2 by Contributor
  • 5666 Views
  • 3 replies
  • 1 likes
blue lines mg8220
I've started getting blue lines of varying sizes on photos off the internet. When I print from screen grag that was downloaded, or a hoto straight to preview, etc. the only pohoto that is clear is from photocopy. I've removed and replaced cyanne. I'v...
debslou2 by Apprentice
  • 7166 Views
Solid orange light. Pixma iP7220
I have looked all throuh the user manual and the only reference I can find to the error light is for a blinking orange.  They don't even mention a solid orange light. Other day just relocated printer to a different shelf.  When plugged it all back in...
Cannot print from rear tray TS6420
When I try to print from the rear tray, the printer ignores the paper I have loaded in the rear tray (a single sheet of semi gloss paper) and instead prints from the main tray. I have confirmed that the TS6420 supports the semi gloss paper that I am ...
pomme007 by Apprentice
  • 3465 Views
  • 2 replies
Printer Profiles Issue
Hi, I am in UK but trying to sort out printing from Lightroom CC, the printer is the Pixma G650 Tank printer, the only option I have in the printer Canon lj Colour Printer Profile 2015  is this the correct one as I cannot see any other profile availa...
bobkent by Apprentice
  • 928 Views
  • 0 replies
Canon TR4550 Printer Wont Scan Anymore
My new  Canon TR4520 Computer Printer/ Scanner stopped communicationg after 2 weeks on my Windows 7 Desktop. It still prints and and is only connected thru a USB Cable. Not Remotely.  Will not self repair..says cannot connect to USB? But it still  Pr...
Pixma MG29505
I am unable to power on the above printer. As soon as I connect the power lead the ALARM light comes on (not flashing) and i am unable to switch on. Advice please. TIA.
Paddock by Apprentice
  • 1917 Views
TS9020 Code 6004
The printer was working fine a few weeks ago. I just replaced the ink cause they were running low and now it's giving me the 6004 code. When it turns on, it'll take paper from the rear loading tray and run it though to the output. I checked for paper...
