Printer works but scanner will not.
Says it is not conected. Printer will print and copy but not scan. MX532 and I use Windows 10
Can anyone help me with this? I replaced the ink tanks, and with no errors prior, ended up with code 6502. I cleaned everything ran it through, another person ended up replacing the ink tanks thinking they were faulty, and still same error code.I the...
Beginning a few weeks ago my g6020 no longer prints photos and/or images from the internet. Documents, pdf's, etc., seem to print fine. I have spent hours on this subject via Google searches. I tried all kinds of seemingly odd things to no avail. To ...
I have the Canon Pixma MP495 and I'm hoping someone can help me. I'm a very organized person when it comes to files and folders on my computer and prefer to have as few as possible. When I scan a document it doesn't give me an option to scan multiple...
I have had an MG7720 printer for a while now and havebeen pleaased witnh it. 2 issues have developed recently. I a,m using it witgh a Macbook Air, O/S 10.13.6Printer Proxy is 13.6.1 Issue 1) Now, faiurly frequently I get asked if I want to install th...
In last month after login to PC Windows 10 connected to above printer. printer was formerly connected to a Windows PC Running Windows 7. Now a few months later my Windows Pc with W-10 after it boots upgive me and error box Top Left Corner says "Canon...
It seems that my MX922 no longer recognizes any option other than scanning to a PC. I have two PCs on my wireless network, but the MX922 recognizes one of them, but not the other. AND, I can no longer scan to a local USB plugged into the lower fron...
Hi. This is the last attempt to fix this problem before I break down and buy a new multifunction printer. I had this installed on my old Lenovo and it worked ok. It was never a great printer, but it worked. Now I have a new Lenovo computer and I trie...
I have cleaned the print nozzles, attempted auto alignment and then manually aligned the heads multiple times, cleaned the encoder/timing strip and the result is that the printer heads are still not aligned. When printing a single spaced document, ev...
Perodically the touchscreen on my TS9521C printer becomes unresponsive. The only thing I have been able to do to work around this problem is to power cycle. Is there a firmware update or something that might fix this problem? It's very annoying t...
My MG5400 will no print barcodes correctly anymore. I have cleaned it with all options and performed all the maintenance. Any suggestions? Thanks
Hello! I have a Pixma MG5520. I had set it to scan to an HP laptop, but that computer is old now, and I have a MacBook Pro running High Sierra 10.13. I couldn't figure out how to set the printer to scan to my new computer. I downloaded the scanner an...
Pring and scan have bneen working. Now, when I try to scan, the printer reacts and appears to scan but then cannot communite with the PC over the lan. Printer and PC are connected to the LAN.
Tried all the quick fixes and nothing has helped. Asking for any help out there before I have to purchase a new printer. I know it's old, but it has been such a reliable printer. This is the first time it's ever given me an error code that has stumpe...
I'm guessing from reading some of the other posts that many of us are waiting for updated drivers/scanning software for Big Sur. Printing on the above printer works fine using wi-fi, but scanning is a non-starter, even with all the latest software do...
| Subject | Author | Posted |
| 09-23-2026 07:16 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
