Desktop Inkjet Printers
PIXMA TR4520 Front Cover
Should I be able to close the front cover on my new PIXMA TR4520 printer without removing the paper? If I send something to my printer when the front cover is closed, will it open automatically?
JNofMN by Apprentice
  • 1511 Views
  • 2 replies
MG2220 printer
I have a briefly used MG2220 printer (in storage) that has a couple of minor problems from sitting. Powers up fine and operates but ink tanks are dry since it hardly prints at all. Ink absorber pads are identified and can be cleaned easily, but does ...
carbon by Apprentice
  • 2155 Views
  • 2 replies
G3202 printer pulling paper sideways
I have a Canon Pixma G3202 printer that I purchased for school in June of 2020 so it is not even a year old yet, not cheap either. It will not print at all because it keeps pulling paper sideways and then the error shows no paper in the printer. I ha...
error code 2 140 3
when i try to scan from the printer or the pc i get this error message. printer in use or error2 140 3. I have windows 10 and the printer is a TS5120. turning on and off doesnt work and resetting the settigns didnt work either.  the scanner works fin...
wepopu by Apprentice
  • 2414 Views
Paper jamming
Hi all, I have a MG6800 and am having a problem with the paper feeding.  When I look into back of the printer it appears that a spring loaded guide is in the open position, and the paper is unable to feed through onto the roller because it is catchin...
DianneG1 by Apprentice
  • 1255 Views
MG 5720 not recognizing A4 paper
My father has a model MG5720 printer.  Recently performed printer head alignment and cleaning after getting error message telling him to put A4 paper in when that is the type paper he was using.  After aliignment and cleaning worked fine for a day.  ...
gregs1 by Apprentice
  • 5209 Views
  • 5 replies
MG5720 cannot change default paper type
Model MG 5720 printer.  The printer insists on printing A4 paper type no matter what change I make to the paper type setting.  I cannot get the printer to change to and print 81/2" x 11" paper setting. I have tried changing setting several times with...
  • 1275 Views
Pixma MG2522 Setup Issues
We just got a new computer, and hooked up the canon printer/scanner that we have had for over a year, but the setup progess keeps having problems. It's on step 3 of a four step process, where the computer and printer are connecting and it's doing the...
bt109 by Apprentice
  • 1630 Views
Resolved! TS3100 wont print
GreetingsI keep getting the same error message but every thing is plugged in and working turning off and on does nothing.     Error   5200CausePrinter error has occurred.What to DoTurn off printer and unplug it.After a while, plug in the printer agai...
Ouisseau by Contributor
  • 9875 Views
  • 6 replies
Pixma MG7120
I recently bought a new Mac and while my printer works just fine, the scanner does not appear under Printers and Scanners. I went looking for the driver download, but the MG7120 is not among those listed.  Does anyone have the solution?
MX870 giving error msg: 6A80
My MX870 gives msg:  6A80 and instructions to power down and power on and if msg persists, see manual.  That error msg is not explained in the manual.  I even unplugged the printer and left it off for several hours.  I just plugged it in and turned i...
Sarisack by Apprentice
  • 76704 Views
  • 28 replies
  • 1 likes
Installation Failure of Pixma MG3620
I have tried to install my Canon Pixma MG3620  I use Mac and have downloaded the latest version of installation software, however, I get to Step 3 and constantly get the Installation Failure which I've attached the screenshot of here.  My printer isn...
