04-14-2020 01:25 PM
Hello, I have the above printer on my computer which uses Windows 8.1 as it's OS. I went to use it today and I can't change from a landscape orientation to a portrait orientation? I've used the printer before without any problem changing the orientation, although this morning I had done a system restore on my computer which only restored it back to April 10, 2020, but I'm not sure if that would prevent me from changing the orientation? Any help would be appreciated. Thank you
04-27-2020 02:55 PM
Hi scorpio012,
The software that Rick is referring to is the software/application that you are using to view the document on your computer.
Examples of this would be Adobe Reader, Microsoft Word, Google Chrome, to name a few.
05-13-2020 01:22 PM
Hi scorpio012,
Please follow these steps:
1. Press the Windows key on your keyboard and the letter R, then let both go.
2. In the Run window, please type CONTROL PANEL and click OK.
3. Click on View devices and printers (or Devices and printers, depending on your view).
4. Right click the Canon TS6300 series and left click Printing Preferences.
5. In the lower right corner, please choose your desired orientation, Portrait or Landscape.
6. Click Apply and then OK.
Once set, please attempt to print.
For more information, please use this link:
https://ugp01.c-ij.com/ij/webmanual/PrinterDriver/W/TS6300%20series/1.0/EN/PPG/dg-c_basic.html
04-15-2020 10:34 AM
A system restore is probably not indicated as a potential fix for a screen orientation issue with your printer.
What software are you printing from?
What are you printing? (text, image)?
04-15-2020 01:37 PM
Hello Rick, Thanks for your reply. I've been trying to print out a document from my computer, a financial statement. Before it's always printed out in the protrait orientation, but now I can't change it from landscape. Being computer iliterate, when you say software I'm not sure what you mean? I bought the printer less that siz months ago and I used the disk that came with the printer. I'm using Windows 8.1 as my OS. Thanks again
04-27-2020 02:55 PM
Hi scorpio012,
04-27-2020 09:18 PM
Thank you for your reply and educating me about computer terminology which I'm obviously in deperate need of. Now that you've explained it to me about what the software program I was/am using is Adobe reader. The problem with the picture orientation is ongoing and I still haven't been able to figure out what the problem is? If you can help I would greatly appreciate it. Thank you
04-29-2020 12:39 PM
Hello, The software you asked what i am using is Adobe Acrobat pro DC
05-04-2020 02:09 PM
Hello, I had posted this question earlier about my not being able to change the orientation of the page when I start to print something like a document. I have Windows 10 as my OS and the printer is a Canon Pixma TS6320 and I use the software that came with the printer. I ho0e that you can provide me some help with this. Thank you
05-13-2020 01:22 PM
Hi scorpio012,
05-14-2020 12:32 PM
Thank you Patrick for sending me this to try. As soon as I do will let you know how I made out. I will be in the hospital for a few days. Thanks again
