03-04-2026
10:40 AM
10:41 AM
It says the printer is offline and the printer won't work
03-04-2026 11:13 AM - edited 03-04-2026 11:17 AM
In order for us to try and assist you, we will need to know the version and build of the operating system you're using the printer with?
Also how the printer is connected and to what?
And last have you installed any drivers, and if so which?
You can use the following for reference:
https://www.usa.canon.com/support/p/pixma-ts6320
03-04-2026 05:01 PM - edited 03-04-2026 05:02 PM
Access Wi-Fi Setup
Make sure printer is powered on. On the printer's control panel, navigate to the Wi-Fi setup option.
Select Wi-Fi Network
Choose your Wi-Fi network from the list. If your network does not appear, ensure your router is functioning properly.
Enter Password
Input your Wi-Fi password using the control panel.
Confirm Connection
Once connected, the printer will display a confirmation message.
Enable Wi-Fi on Smartphone
Open your smartphone's Wi-Fi settings and connect to the network that starts with "Canon_ij_".
Open Canon App
Launch the Canon app and follow the on-screen instructions to connect the printer to your home Wi-Fi.
Complete Setup
After following the prompts, the printer should be connected to your Wi-Fi network.
Test the Connection
Print a test page to ensure the printer is connected properly.
Troubleshooting
If the printer does not connect, double-check the Wi-Fi password and ensure the printer is within range of the router.
