I can't connect to my MG5220 wirelessly now that I'm using Windows 8
Hi,I bought my printer a couple of months ago and it worked fine. Until a few days ago it just broke down with a code error 5011...I came home turned it on and 'beep beep beep'. I am unsure what happened. I know I was running low on ink so I bought i...
HiI'm a student in a big shared flat. Because we are using the same wifi everyone can print on my Canon MG7150. Is it possible to see who had printed or better can I change the settings that only I can print (maybe MAC or IP...?). Thanks in advanced...
The Unit will NOT power on. Only the Yellow ALARM LIGHT stays on. Tried unplugging etc!
Does anyone know what the closest replacement is for a Canon i960 printer?
My trusty Pixma MX850 finally went the way of the B200 error. Tried everything, no luck. It is about time to move on anyhow. It looks like the new pixma 850 replacement, the MX922 is a disaster riddled with problems. So what do you recommend inste...
As above. I am looking for tutorials or classes in the Washington, DC area to help learn how to us the PIXMA MGS 5420 printer/scanner/copier I just bought. I find the Manual is too confusing and poorly written. Maybe Canon has places where this in...
I would like to use the fax of my Pixma MX700 to send a number of files in a single call. Can I create a list of the files and send them as one?
how do I check ink levels with pixma MG4250
I have a canon MG2120 and when I scan a photo it makes it a PDF file and I cant open them. It wont let me do anything with the photos. Can not open,save to fb or anything. Was wondering if there was a way to download as a JPG or to convert the files....
Any way to set MG 3220 to print black and white only? Happy Holidays
Only choice on film size 35mm (optioned is grayed out). I have old 127 format slides that I want to scan, and not have cropped to 35mm. Any solutions?
I have a Canon Color ImageCLASS MF8380Cdw laser printer. I print using the wireless connection from both an iMac and an HP Laptop. I haven't successfully scanned using the wireless connection. Is it not an option with this printer? I don't see wi...
We recently installed a bunch of MF4890dw multifunction printer/copier/scanners on our network. Is there an easy way to manage these over the network? I know I can access each one individually through its IP address, but the amount of control is li...
Two questions....it came with a strange looking white plastic "thing"...we cannot tell where it goes. Also where is the "copy" and "scan" buttons?
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
