How to print roll of paper w 25mm/ h 5000mm or similar format on Canon pixma ip7250.
How to print roll of paper w 25mm/ h 5000mm or similar format on Canon pixma ip7250.Costum max dimension does not allow .
I have code 1312 that i cannot clear, there is no paper stuck in the machine, did anyone run into this before any advice would be appreciated thanks.
Hi, haing recently moved from Australia to CT I purchased replacement ink and inserted the cartirdiges. Whilst the actual cartidge numbers on the pack were different to those used in Aus, the pack had MX870 as being supported on it. The printer state...
I have a Canon MG6450 which works fine via the USB. When I try and use it with WIFI the printer is always offline. The scanner works fine via Wifi. The printer is connected to my WIFI router ok and I can ping it from the Windows 7 PC. I have AVG ...
I need to re install my printer to my laptop, but lost the disc for MX410.
Hey all, I've actually submitted this to Canon support, but I thought I'd bring up the issue since it's pretty strange and I would think that anyone familiar with it might see this post and go... "Oh hey, I know that!" So... Pixma MX922... I appear t...
I have a MX922 hooked up through Google Cloud Print. Every thing works pretty well except two things: When the print dialog comes up there is not optin for printing multiple copies.There is no option to print only in black and white.Also, using a Chr...
Just purchased a new MX920 and set it up following the enclosed directions. It won't auto-adjust the head alighment. In fact, I can't make it print anything at all. Regardless of what I try, it feeds a blank page. I have to think I've missed someh...
I use an iMac with Yosemite OSI and an MG7520 printer. notice on my MG7500 series Quick Menu that the Print as well as Device setings and maintenance toolbars have no icons; they're blank. The Scan, Web services, and Manual and device information has...
How do you scan a document on the Canon MX450 printer and send it to your computer?
I am running Windows 7 and am hardwired by usb to the printer. I have used every cleaner and alignment process offered by Canon and I still get Double text that is unreadable when printing from the internet? Help!!! Thanks
I have a pixma 6320 and the screen is showing an error code 6000. I opened it up and found this white piece lodged behind the cartridge. Any idea where this goes inside? thanks
I am getting a Suport Code 1403 "The type of print head is incorrect. Install the correct print head". I have no prints pending or in progress. Print is brand new - two weeks old, I have removed the print head twice and reinstalled, I have powered do...
best color management setting for mg5520 printer
| Subject | Author | Posted |
| 09-20-2026 01:49 PM | ||
| 09-20-2026 12:09 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM |
