01-29-2014 07:34 PM
It says my ink on my printer is low but when I try to print things absolutely no ink is printed on to the paper. I feel that even though it is low it should still apply at least a little bit , making the characters look faded. IM concerned my printer needs to be fixed and may be broken. Please help.
02-27-2014 06:49 AM
Hi coleyv,
Depending on how low the ink is, ink may not be applied to the paper. You can print a nozzle check pattern from the printer to see if the inkjet nozzles are dispensing the ink correctly. To do this, please follow the steps at the link below:
Printing a Nozzle Check Pattern
If the inks are not printing correctly, replacing the low ink cartridge(s) in the unit should resolve the issue you are experiencing.
03-07-2014 11:17 PM - edited 03-07-2014 11:18 PM
I too faced this problem with my printer. Then I start searching for the best solution. Well, I am going through your thread, I gained some knowledge and also helpful those sharing information for solving my problem.
