I have a PIXMA MX490 printer- error code 5011. can you help me about this error
I have a PIXMA MX490 printer and it display an error code 5011. Can you help me fix it
just purchased Pixma MG3620, as a replacement to an older version pixma, and had no issues with setup, installation, or wireless connection. Attempted to insert scanned photo directly from scanner to excel document, received multiple cause error mess...
I am using a Canon MX922 printer on a Mac. The drivers that are installed are up-to-date. I have tried to adjust the color intensity but, it doesn't seem to follow the same procedure that a Windows device would follow. Any help would be greatly appre...
Printer is connected to laptop with a USB cable. Prints way too slow. Starts to print, stops for a while, prints several lines, stops for a while, prints some more lines, and so on. Printed faster when hooked up wirelessly. Can no longer use wirel...
Anyone successfully using the MX870 with Mac O Catalina?
The PGBK ink will not print. I have tried a deep clean and replaced the ink cartridge. With no results. When the test page is printed the grid lines don’t print. How do I resolve this issue
New printer. Set up drivers and was working for a day and plugged it into smart surge [rotector. I went to use it and said Printer was turned off wrong bc did it from phone. ISP number and network info was correct when printed out. Went to print and...
Hi, anyone who can help I would appreciate this. Just received this printer in the mail, and set it up. Went to print my first photo and it prints only out of the paper tray (no paper in it) and it does not recognize the matt textured, paper sized ...
both the on light and warning light are blinking one after the other. Both ink catridges stuck all the way to right side.
Hi I have brand new printer only ever printer one piece of paper now it say no paper loaded even though there is tried all cleaning function in menu but as it say there is no paper they dont work properly, put brand ink cartrigdes in still says the ...
I bought a cannon MG3620 because it said it would work with OS10.6.8 - now I cant get it hooked up - can anyone help me? thanks in advance
Is the ts8120 designed to work with WiFi? I think "WiFi" is the correct terminology, by that I mean that is doesn't need to be connected with a USB cable Thanks..
I am having printing problems which are related to misaligned print head. I have set up again and still the same problem. I am thinking of replacing the printer and would like to know recommendations for a similar spec machine.
I just got this printer. I went to scan a page today my printer is not recognized on the screen of the printer. So I opened the Canon IJ Scan Utility2 and I get this message on my computer Cannot communicate with scanner for these reasons:- Scanner i...
My Canon MG2950 will do a test print no problem but wont actually print anything else. I have done deep cleaning and every other maintenance thing, but it wont respond. I have downloaded and installed the latest drivers from the Canon homepage as wel...
| Subject | Author | Posted |
| 09-06-2026 02:35 AM | ||
| 09-05-2026 05:47 PM | ||
| 09-05-2026 10:28 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM |
