Can my Canon Pixma MX922 Print Avery return address Labels?
Good morning!I can't figure out how to print Avery return address labels on my Canon Pixma MX922 printer. Does anyone know if this can be done?Thanks in advance.
I was trying to carefully replace the yellow printer cartridge on the above inkjet printer, when the locking tab sheared off, I was not using any force, just finger pressure as usual, so I assume it was a plastic failure in situ. Now I have the cart...
I have a pixma mg3220 running windows 7, it started printing a bad shadow. So i am trying to do the print head alignment procedure but every time it tries to print the alignment page it stops 1/4 of the way in and i get a P02 error. I have to power o...
I have macbook air. OS version is Mojave. I can not print anything from my G3410 printer. Printer works fine when I connect from my android phone. When I try to print a document from my mac, It says "Printing" and after some time I get error code 3...
Hi all, Am struggling with printing DVD discs using Windows 10 and Acoustica Label CD Maker on my TS8250. There is no option to select the multipurpose tray in the printer property options. When I select Printable Disc as a media type from the list...
Mx922 error support code 1007, there is no paper in cassette upper. I have paper in the bottom cassette. The upper cassette is for envelopes pictures etc... I checked the paper and adjusted to fit tight and it still won't print.
printer set up does not work,getting message 'connection failed '
Anyone have any luck clearing a B200 error code.all of a sudden the Pixma XI 6820 printer driver refuses to recognize the ink carts, the printers lights are on for all the carts so it sees the full carts.I've turned off the power and let it sit, I'v...
Hello everyone. I have Canon Pixma iP1800 that has not been used for 10 years. It has been siting in storage room crimped in plastic foil, so it has no dust anywhere. It has no cartridge since then.So my question is: Is leftover ink from 10 years ago...
I am getting an error code of u052 on my mg5320 printer. I last printed successfully about a week ago. Today I changed the ink cartridge and am now getting error code U052 regarding the printerhead. I have verified that the ink cartridge is the corre...
I read somewhere that when you turn on your Selphie printer, the ink cartridge advances, thus wasting the cartridge. But from what I remember there is something you do when you press the power button to prevent that from happening. Does anyone know w...
Hi - I have MX452 printer. I downloaded the Canon IJ Scan utility also. I can print wirelessly no problem. However, when I attempt to scan I get a message that the scanner is not connected. When I click on the scan tool - it also tells me PC is not c...
Hi all... when I print out an image the white borders around the print are uneven... wider on one side and bottom. I am using this printer for the first time. Its all set up to my desired specs. The window on the left that shows the image in the ...
The printer continues to flash orange and states support code 1300. THere is no paper jam anywhere. When I turn the printer back on, it takes a piece of paper and slides it through. I cannot click roller cleaning as the troubleshooter recommends. ...
Hi, I have a Canon Pixma 2522. I am getting the error message error message 1700 Ink absorber is almost full. This has happened to me many times before. I do a lot of printing and the counter in the printer would display this error message whether t...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
