Desktop Inkjet Printers
TS5320 Burns through ink
I have a TS5320 printer that I bought in 2020. I don't use it that often, but I noticed when I first purchased it, it seems to run through ink incredibly quickly. I called customer support and they said it didn't sound normal so they offered to send ...
Resolved! Can't set up pixma MG2500
I'm following on screen set up instructions to the point of aligning print heads, but the A4 sheet I've inserted won't print. The document shows in the print queue but that's it - nothing happens. So I can't complete the set up process. I should say ...
voyeuse by Contributor
  • 155081 Views
  • 19 replies
  • 3 likes
PIXMA MG8120 Error 5020
I have an error message on my printer which reads:5020Release the scanner lock switch and turn off power then back on again.I need a detailed instruction to correct my printer problem.Edgar[Email address removed per forum guidelines.]
PIXMA G2020 Support Code 1726
Hi! Do anyone have any idea if I can still use my scanner, my printer is Canon G2020, I have a support code 1726, which I know I need to replace the maintenance cartridge, my concern is, if I can continue using my scanner while I am not able to purch...
Margie19 by Apprentice
  • 2189 Views
  • 0 replies
  • 1 likes
Resolved! Canon PIXMA TS3522 Shutting Off When Idle
We have a new printer, Model Canon PIXMA TS3522.  The printer is located in another room and when we want to print from our I pads, invariably the printer has shut off.  Is there a feature where the power can be constantly left on?This is very unhand...
astramel by Apprentice
  • 7046 Views
  • 3 replies
  • 4 likes
