Scanners
Getting the dreaded Code 2, 156, 33 on new Canon Lide 400
I bought a Canon Lide 400 at an Office Supply Warehouse several months ago.  It was sold as new.  This particular local office supply place sells older models of new office supplies.  It has been several months since I bought it or I would take it ba...
Linear by Apprentice
  • 59 Views
CanoScan LiDE 400 Driver install needing Administrator
Downloaded the driver and software package. After I extract the files it gives me this message.Problem: To install the software, you must be logged in to an administrator account.Click [OK] to cancel the installation. If you are using the CD-ROM, rem...
CanoScan LiDE 220 How to remove glass for cleaning
I've seen videos for removing glass for other Canon scanners by using a screw driver around the edges but this doesn't work for 220. How do I remove the glass so I can clean the underside?
cool09 by Apprentice
  • 58 Views
  • 0 replies
Canon DR-G1100 scanning noise
https://www.veed.io/view/2da3bea4-704a-4235-b31b-84d0aa3c822c?panel=share  any ideas? Thank youscanner hardly had any use circa 40K scans
Lide 300 Photos not sized, have white space around them
When I scan a photo using the IJ Scan utility (or any other scan software for that matter), the resulting image is not cropped and contains a lot of white space from the surrounding area of the flatbed.  Running Win 11.  What is the solution?  Works ...
spetrovi by Apprentice
  • 1940 Views
  • 4 replies
Image Capture hijacks my LiDE 400
I just received my Canoscan LiDE 400, to be used with a Macbook Air running Tahoe 26.2. After installing the Canon software package I could not get IJ Scan Utility Lite to recognize the scanner, and found that Apple Image Capture had automatically hi...
susanep by Apprentice
  • 123 Views
  • 2 replies
Windows 11 (and Windows 10) not finding imageFORMULA DR-C125
I have a DR-C125 that I've owned for years that no longer communicates with two of my computers even when I try USB cables that work just fine with other devices.  I've uninstalled the device via Device Manager and reinstalled drivers/software numero...
LIDE 400 Failed to make a connection to the device
I have a Canon LIDE 400 scanner connected to an M1 MacBook Air running Tahoe 26.2.  I have reloaded the scanner, updated the scanner driver to Tahoe and rebooted the laptop.  When I plug the scanner in via an adapter to the USB-C port, I hear the sca...
Resolved! imageFORMULA R40 Document Scanner unable to change margin
Using the R40 to scan in sports cards, it is important for me to have a margin around the edges.Page size is set to match original size when I click on scan area the margin slide bar is greyed out.I've tried to look in the manual and online but can f...
CanoScan LiDE 500F with Windows 11 - Can Not Scan
Hello,  I have a CanoScan LiDE 500F scanner which I've been using for many years with a Windows 10 (64-bit) laptop.  Recently I bought a new laptop - Windows 11, and after installing the Canon software from the original media, I found that the scanne...
Bob29 by Contributor
  • 9852 Views
  • 11 replies
Windows 11 doesn't see imageFORMULA DR-7550C
I have a friend that has a DR-7550c scanner and just recently replaced her PC with a new one running Windows 11. She was using Capture Perfect 3.0 to manage it on the old PC and we've installed it on the new one, but it does not see the scanner as be...
gtifeld by Contributor
  • 202 Views
