Printer won't print pictures, only text Options
hey guys, I have MX 310, it prints only text options, no pictures I did give order to print and chose the MX310 from the lest and it starts and then the paper comes out clean, any idea guys? thank you.
Hi, I just bought a PIXMA TR8520 and I want to make sure that I have the option to print if the internet is not on before I unpack and set the machine up. I read online that there is an option and that a cord comes with the machine. Obviously that w...
My printer started showing error 1405 out of the blue. It is now inoperable. I saw the lawsuit canon paid out in 2015. (Said its programmed to fail after the warranty runs out). Is this true or your experience?I need to buy another printer. Typically...
will print but not copy; gives error code 2110
I find I can print a document saved as PDF but not one scanned on my printer and saved as jpeg. But I can email that same document to myself and print it from the email. What is going on here?
Hi, I have a paper document of lets say 10 pages. I want to scan it ito a single pdf document. It is possible to do with the Canon IJ Scan Utility. But one has to run back and forth between the computer and the scanner. Because one has to put the nex...
I installed a new color ink cartridge last night and the colors are faded and blue. I've checked the manual and tried to follow the steps to print a Sample Patterns page so that I can adjust the colors, but it backs you out of everything you do and ...
Canon PIXMA MX892Network printer (Win7 and WinXP) When printing photos, it will not print BLACK completely. It prints black as grey. Does the same thing from both XP and Win7 computers. Does the same thing no matter what software I use. I've uninsta...
I just bought the Pixma MX922 printer and I can't stand the My Image Garden Software! It is not intuitive nor helpful in making CD labels. It does not allow any modifications to the STANDARD layouts. I am accostomed to using the Epson CD software ...
My PIXMA MG5320 printer and scanner has worked fine for well over a year. Suddenly, my scanner takes a very long time to heat up before actually beginning the scanning. This happens with each page scanned. Then, when scanning a multi-page documen...
When duplex is turned off only get header in print test page.I've tried about everything out of ideas.
My Pixma MX492 prints ok but when I try to copy something, there are lines out of place and things are jumbled up in some places. What could be wrong with the scan function?
Never had issues before but pushed on button and mx922 started for about 10 seconds then immediately shut down. The printer was in a stable location where it operated for several months. There was no unusual noises or electrical issues. Tried the "o...
I have an ip 2702 PRINTER THAT I FAILED TO ORDER THE xl CARTRIDGES FOR. iNSTALLED THEM AND THEY WERE PRINTING OK UNTIL I GOT THE "RUNNING LOW ON INK" MESSAGE AGAIN. WHEN I REMOVE THEM AND SHAKE THEM, THERE APPEARS TO BE LOTS OF INK INSIDE THEM STIL...
Hi all,A friend has just given me a brand new TS9020 Pixma printer. I downloaded the driver and all the software. The printer shows up as a new printer on my print menu, so the computer recognizes it. (W7) I went through the steps to connect it to my...
| Subject | Author | Posted |
| 09-15-2026 11:48 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
