PIXMA MX870 How do I correct odd page upside down while duplex printing?
RMIGHTY1
My MX870 prints every other page upside down while printing a catalog in duplex mode.  How can I correct this? The catalog was written using MSWord 2007. Obviously, I can manually duplex the catalog. I am praying there is a solution to be able to automatically duplex.
Thank you.
7 REPLIES 7
Michael
Hello RMIGHTY1.
When you enable the duplex printing option, please choose the Page Setup tab in the printer settings.  Then change the 'Stapling' setting to the desired 'Short-side'.  This should correct the way the duplex printing is performed.  The default option is Long-side left.
Thank you Michael for your response. I have tried that and it did not work. What I did do however is d/l and install the latest driver from the Canon website. Upon installation of the driver, windows7 automatically also installed their driver having a "WS" suffix. That driver did the trick and it is now duplex printing for me just fine. Thank you again for your response.
montyrosen
After 3 days of futile efforts to solve odd page upside printing in duplex print. The problem was solved as follows:
Go to the print menu
1. Go to quick setup
select "Preview - Duplex - Paper size - Orientation [make sure document and printer orientation are the same}
2. select "page setup "
on page layout select "normal size print" - "duplex automatic" - "stapling left side"
Print area setup  "select - used reduced printing"       Selection of " use reduced printing" is the key to solving the problem
3.  Problem solved
yorkyeshine
Please, Please, can someone tell me if there is a setting to beable to change my canon Pixma 5650 from printing my alternate pages upside down.
Thank you a million for your tme and your awesome sharing. After many times of unsuccessful tries of printing all of sudden I met your solution here and it solved the problem perfectly. I appreciate you again for your awesome sharing. All my bests.
Solution didn't work for me
Thank you montyrosen!
This solved my duplex upside-down-reversed problem on MG7520 in 30 seconds!!
