Desktop Inkjet Printers
PIXMA TS6100 documents stuck in print queue
I've had the same issue and managed to use the stop the printer spool queue.  I have a Canon TS6100. I have found this the most tempramental printer ever owned. It took two days of trying to get iot to actually register everything correctly with our ...
Pink tint black and white pixma ip8750
PLEASE PLEASE PLEASE help me before I go insane. EVERY black and white picture I print is PINK, i am new to this industry and i need a SIMPLE  AND IDIOT-PROOF explanation of what to do.  I using an IMAC, the printer mentioned above and i am printing ...
Canon printer not printing in all colours
I have a Canon MG5650 printer. There was still some ink in Magenta but it was saying otherwise so I put in a new cartridge and although it's indicating full the magenta colour does not printI tried cleaning and nozzle checks but all I achieve is usin...
Canon TS9120 Error code 2,157,50
Hi I recently bought a Canon TS9120, for the first week it worked fine, scanned pictures and documents no issues. Now this week it keeps giving me the error code 2, 157, 50. I am using Windows 10 -Scanner is turned off-(If using Wired LAN connection)...
mg6320 won't recognize cli-251xl
I can't seem to find an anwser to this question anywhere.  Cli-251 black is the recommended ink but my MG6320 will not recognize the "xl" tank. Is this correct - xl size can not be used in this model - or do I have a different problem?
CD-Label Print
My computer recently upgraded to Windows 10.     I have used CD-Label print for years and I need to know how get it on Windows 10.      I have a Pixma IP5300 which is able to print normally with the Easy Print Toolbox, but the CD-Label Print is missi...
Tom1 by Apprentice
  • 15105 Views
  • 6 replies
MX922 printer
support code  coooPrinter error has occured, follow steps below.1. Cancel printing then turn off device.2. Turn on again if problem persist  see manuel and contact the service center. Did all the above and still get the same error .
MX922 Wants to Test Print a Fax
I have set up and connected my Canon MX922 wirelessly to my hp pavilion pc running Windows 10. When I try to do a Print Test Page, nothing happens and when I look at printer properties it appears that it is wanting to send a FAX rather than print a d...
jwulmer by Apprentice
  • 2659 Views
Pixma ix6820
my 2 year old pixma ix6820 will not recognize print carts, and trying to reinstall the driver to clear the B200 error, it will not respond to the driver install.What a bit of junk. Heading to the electronics recycling
