Desktop Inkjet Printers
Pixma MG8220 small business card jammed HELP!!!
I was trying to print information on the back of a business card. The card got jammed and I can't even see it to remove it... I tried removing the bottom paper feed tray, nothing there.I've opened the printer like I would replace ink and I can not s...
AbbeG by Apprentice
  • 3332 Views
  • 5 replies
Resolved! Canon i860 does not print
Canon i860 stopped printing. Nozzle check sheet is blank. Printer in excellent condition (this is the backup printer, little used, almost new). No error codes. No flashing amber light. Solid green. Reset waste code. Replaced printhead with new printh...
takaoki by Apprentice
  • 3738 Views
PIXMA MG3620 Windows 10 won't set up properly
Have tried to set this printer up numerous times by different methods with no luck. It prints but takes a long time to print.If I go into troubleshooting it doesn't find any problems. The Windows printer test page says it was correctly installed.If I...
JIMDI by Apprentice
  • 5029 Views
  • 3 replies
Canon ScanGear configuration under Linux
Hello ! I am using my Canon MG5300 printer with ScanGearMP and Linux Mint. Unfortunately the ScanGear window opens in an unusefull shape every time I open it.Also the configuration of the settings need to be repeated every time I start it. How could ...
nilli by Contributor
  • 12669 Views
  • 3 replies
iP8720 Printer-Photo Sizing Issues
I have a Canon iP8720 Photo printer and Windows 10. I also use GIMP as my photo editor, which is almost identical to Photoshop.  I'm trying to print a 12x18" photo on 13x19" paper, and it won't do it properly. In GIMP, I've scaled the photo to 12x18"...
Resolved! MG7120 printer won't turn on.
MG7120 printer power light comes on along with a yellow/orange triangle light but the screen is blank and will not show a trouble code. Unpluged the power cord and waited two minutes and still nothing. Unpluged it again and waited two hours and tried...
PIXMA MX922 - Support Code 6000
I am getting a support code 6000 message.  My priter cue is empty.  I have shut down the machine and power source and the message still appears when I power it back up.  The machine has no functionality with this code present.
Do I need all ink cartridges to funcntion
Hello and thanks in advance for any help you can offer. I have a Canon iP4820 that came with a piece of equipment I bought used. I purchased a PGI-225 ink cartridge. Tried it and it will not print. properties are set to grayscale. Do I need all cartr...
jbundy77 by Apprentice
  • 2877 Views
  • 3 replies
CD Tray constantly rejected TS8150
Printing CDs with a label on them used to work fine but now I cannot get the printer to think there actually is a CD tray inserted. No matter in what way I place the CD tray it just pushes it out and says there is no disc tray inserted. I have cleane...
Won't print
Brand new pixma 6820.  Everything is on, plugged in correctly.  Will not print jobs in the Q.  Does anyone have any suggestions.  Thank you.
tuctam by Apprentice
  • 13904 Views
  • 9 replies
