pixma ix6820 not communicating with laptop
Help! Can't print
Help! Can't print
Whenever I try to print a document it seems it skips parts of it, or prints very faded. How do i fix this ???The ink is brand new - full cartridges thanks in advance for any help
My MG5520 had a paper jam. It has been cleared and no other paper is still stuck in the machine. All ink cartridges are full but it will not print. It’s getting the signal and goes through all the motions but the paper is blank.
can anybody help me with this code
I have an old Pixma MP560 - which worked very well when I last used it several years ago. I would like to know what I need to do in order to reactivate it without problems: I realiuze I need fresh ink; is there any kind of technical clean-up work ...
I have done several cleanings and used all my ink that came with the printer. I done several alignments to see if it fixed it and everything i have done i am getting a vertical line on the nozzle print sheet even after the deep cleanings. I ve only h...
I have a Pixma MX 492 printer/scanner.I had a paper jam when scanning and continue to get the ADF paper jam error message.Here is what I have done so far to attempt to fix the problem not necessarily in the order performed : Cleared all paperTook the...
I just purchased an iP8720 printer and I have been trying to make 12x8 prints using 13x9" photo paper. I print directly from Lightroom. I use 4x6 as my standard in-camera aspect ratio and I like 12x8 prints because they are a 4x multiple and I donot ...
My MG3200 is locked up with a P07 error code. Does anyone know how to reset the printer ink blotter counter so the devise will operate again?
MY MX 450 PRINTER HAS STARTED PRINTING VERY SLOWLY. AN ADVERAGE DOCUMENT WHICH TAKSE ONLY SECONDS TO PRINT, NOW TAKES SEVERAL MINUTES.I REPLACED AN EMPTY CARTRIDGE AND WHEN I TRIED TO PRINT, THIS ISSUE BEGAN. THINKING IT WAS A BAD CARTRIDGE I TRIED...
Started off as 'Document Scan' (scanning multiple pgs in one PDF) not working off of the full (not lite) Canon scanning utility app on Mac to now the entire set scanning utility functions are missing off of my Canon Quick Menu. I did no recent upgra...
I've had the same issue and managed to use the stop the printer spool queue. I have a Canon TS6100. I have found this the most tempramental printer ever owned. It took two days of trying to get iot to actually register everything correctly with our ...
How do I get OCR software
PLEASE PLEASE PLEASE help me before I go insane. EVERY black and white picture I print is PINK, i am new to this industry and i need a SIMPLE AND IDIOT-PROOF explanation of what to do. I using an IMAC, the printer mentioned above and i am printing ...
I have a Canon MG5650 printer. There was still some ink in Magenta but it was saying otherwise so I put in a new cartridge and although it's indicating full the magenta colour does not printI tried cleaning and nozzle checks but all I achieve is usin...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
