PIXMA TR4522 Error Code 1430
i have pixma tr4522 and put a new ink cartridge in it and it the ink that is takes and i keep getting an error code of 1430 can anyone help me know why it is doing this.
Recently my PIXMA TS 6220 has begun making a clicking sound when trying to print. I have made every attemppt to troubleshoot this issue by restarting, unplugging, and checking for debris in the unit itself. I have had no luck with any of this. The tr...
I have a new Canon TS8350 and the PGBK cartridge that came with the printer (official) is not printing. Whenever I print the test pages there is no PGBK line and black text is coming out slightly blue. Any suggestions? I do not want to buy another ...
I have a Pixma MG7120 and run it on MacOS Catalina v10.15.2. Since the Catalina upgrade I have not been able to scan from My Image Garden. The option is there, but it is greyed out. I have gone through the listed drivers on your product page and n...
My Canon Pixma TR 4520 continues to print old jobs at random. There is nothing in the print queue and we have powered down and even unplugged the printer to try and clear any print jobs but to no avail. It contines to print an old job. Right now t...
Hi all, when printing, it basically "jumps over" an entire vertical column of the paper, leaving that entire column blank, and then distorting further and further as it moves to subsequent lines. I've attached an example of the print test, because al...
This is going to be long - I apologize in advance! I recently purchased an MG3620 and I was able to successfully run the Setup procedure on my laptop running Windows 8.1 - I set it up as a USB connection because in the past I've not been able to use ...
Hello! I am trying to scan a document and retrieve it from the Canon, it scans correctly and I can print directly from the printer, however there is no Canon Utilities in my Start and Apps menu, only a folder with a "readme" file. I looked to downloa...
Hello, Subject says it all. Whether from panel or through Windows 10 or through macOS10.14 produces the black bar running vertically through the scanned document. Copying does not produce this black bar. I have updated the software, drivers, etc. i...
I recently changed ink cartridges in my MX870 printer. It will now not print documents from my computer. It will however print the nozzle check test page. The paper feeds as it is supposed to do, but no ink on page. Does anyone have any ideas on wh...
Pixma iP7200 printer "Yellow light" is on when power cable is plugged in. If I press the power button, the "white light" is on, but the "Yellow light" is still on. At this point, if I press the "white light" button, it won't turn off. The Pixma iP720...
Hi, I got a new laptop running windows 10. Downloaded the drives from canon, but I cannot connect the printer to the laptop. Keep getting an error of "new port cannot be created 0000" Tried to uninstall and re-install, but no changes. Any help I can ...
I have a Mx439 all in one and I thought I set the fax up right but it will not transmit. I get a dial tone and it calls the number I am trying to fax to and once the other fax machine picks up and makes all of its noises my fax doesn't connect to it ...
I recently replaced my MX350 printer with an identical new machine. I use Windows10 and a wireless connection (which is strong). Since swapping to the new printer, I can print without problem, but, when I try to scan from my computer I get an err...
Hi - I have a MX922 that is a couple years old. I just got the Error Code 1405 that says "The Type of Print Head is Incorrect". I have not done anything to the printer. It started spitting out blank sheets in the middle of a print job. I have turned...
| Subject | Author | Posted |
| 09-18-2026 11:59 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
