Desktop Inkjet Printers
MG3620 Printer Replacement Cartridges
About 5 months ago I bought a MG3620 printer and have been using aftermarket/remanufactured ink cartridges ever since from Amazon because genuine Canon ones cost twice as much. No problem until the other day. When both PG-240XL and CL-241XL cartridge...
Oldyellr by Enthusiast
  • 5907 Views
  • 3 replies
PIXMA TR4522 Error Code 1430
i have pixma tr4522 and put a new ink cartridge in it and it the ink that is takes and i keep getting an error code of 1430 can anyone help me know why it is doing this.
Anonymous by Not applicable
  • 2897 Views
PIXMA TS 6220
Recently my PIXMA TS 6220 has begun making a clicking sound when trying to print. I have made every attemppt to troubleshoot this issue by restarting, unplugging, and checking for debris in the unit itself. I have had no luck with any of this. The tr...
Canon PIXMA TS8350: PGBK not printing
I have a new Canon TS8350 and the PGBK cartridge that came with the printer (official) is not printing.  Whenever I print the test pages there is no PGBK line and black text is coming out slightly blue. Any suggestions?  I do not want to buy another ...
SaijoBob by Apprentice
  • 1893 Views
  • 0 replies
Resolved! Scanning Issues with MacOS Catalina
I have a Pixma MG7120 and run it on MacOS Catalina v10.15.2.  Since the Catalina upgrade I have not been able to scan from My Image Garden.  The option is there, but it is greyed out.  I have gone through the listed drivers on your product page and n...
PIXMA TR4520 prints old jobs
My Canon Pixma TR 4520 continues to print old jobs at random.  There is nothing in the print queue and we have powered down and even unplugged the printer to try and clear any print jobs but to no avail.  It contines to print an old job.  Right now t...
mwalla19 by Apprentice
  • 8716 Views
  • 4 replies
Resolved! MG3620 Missing a whole column while printing
Hi all, when printing, it basically "jumps over" an entire vertical column of the paper, leaving that entire column blank, and then distorting further and further as it moves to subsequent lines. I've attached an example of the print test, because al...
yasz73 by Apprentice
  • 4628 Views
  • 4 replies
MG3620 issues
This is going to be long - I apologize in advance! I recently purchased an MG3620 and I was able to successfully run the Setup procedure on my laptop running Windows 8.1 - I set it up as a USB connection because in the past I've not been able to use ...
Resolved! Canon MP280 "Canon Utilities" missing, Windows 10
Hello! I am trying to scan a document and retrieve it from the Canon, it scans correctly and I can print directly from the printer, however there is no Canon Utilities in my Start and Apps menu, only a folder with a "readme" file. I looked to downloa...
Calmca by Apprentice
  • 7186 Views
pixma TS9120 Black Bar On Scans Not There On Copies
Hello, Subject says it all.  Whether from panel or through Windows 10 or through macOS10.14 produces the black bar running vertically through the scanned document. Copying does not produce this black bar.  I have updated the software, drivers, etc. i...
Frank_G by Apprentice
  • 4611 Views
  • 5 replies
MX870 not printing
I recently changed ink cartridges in my MX870 printer.  It will now not print documents from my computer.  It will however print the nozzle check test page. The paper feeds as it is supposed to do, but no ink on page. Does anyone have any ideas on wh...
MG6220 wireless problem.
Hi, I got a new laptop running windows 10. Downloaded the drives from canon, but I cannot connect the printer to the laptop. Keep getting an error of "new port cannot be created 0000" Tried to uninstall and re-install, but no changes. Any help I can ...
Chenix by Apprentice
  • 1720 Views
My fax won't transmit
I have a Mx439 all in one and I thought I set the fax up right but it will not transmit. I get a dial tone and it calls the number I am trying to fax to and once the other fax machine picks up and makes all of its noises my fax doesn't connect to it ...
Resolved! Pixma MX350 will print but not scan on LAN
  I recently replaced my MX350 printer with an identical new machine.  I use Windows10 and a wireless connection (which is strong).  Since swapping to the new printer, I can print without problem, but, when I try to scan from my computer I get an err...
