03-11-2020 05:28 PM
I have done several cleanings and used all my ink that came with the printer. I done several alignments to see if it fixed it and everything i have done i am getting a vertical line on the nozzle print sheet even after the deep cleanings. I ve only had the printer since January. My printer is a TR4520. I have to buy several new cartridges due to the fact im going through too much ink trying to fix the problem. I need my printer for projects I'm doing.
03-11-2020 09:50 PM
Give Canon a call at 1-800-OK-CANON.
03-12-2020 08:57 AM
Hi, Tina62!
So that the Community can help you better, it would really help everyone to see a scanned image of a printout that exhibits this problem. Once everyone can see what you're dealing with, it'll be easier to arrive at a solution.
Thanks and have a great day!
03-14-2020 01:20 AM
03-14-2020 08:02 AM - edited 03-14-2020 08:04 AM
Do you mean what appears on the glass?
It seems to be limited to the glass and follows the contour of the glass. Are you sure it isn't part of the image? If it was a printer problem I would expect it to be linear.
03-14-2020 10:55 AM
No its not part of the image. This is the original picture., there is no rainbow in the water under the boat . I just put the print from the glass on it and have to redo it.
03-14-2020 10:57 AM
It has happen to several photos i have printed
03-14-2020 11:06 AM
