Reactivating an old printer
Hamanhanger
I have an old Pixma MP560  - which worked very well when I last used it several years ago.  I would like to know what I need to do in order to reactivate it without problems: I realiuze I need fresh ink;  is there any kind of technical clean-up work needed?  What about compatibility with Windows 10, and does it need new software, (firm software, drivers, etc)?
The MP-560 is supported under W10.
https://www.usa.canon.com/internet/portal/us/home/support/details/printers/support-inkjet-printer/mp...
What you might have problems with:
Print head and ink delivery system.
If left to sit without use or maintenance, the system can clog.
The following articles may help:
https://support.usa.canon.com/kb/index?page=content&id=ART133166
https://support.usa.canon.com/kb/index?page=content&id=ART131551
If it were me, I'd remove the print head and soak / clean it out.  This has to be done with some care.
aftermarket inks are $15
canon inks about $50
Might want to test it with aftermarket ink to start since cleaning it doesn't guarantee it will work.
1 REPLY 1
