Desktop Inkjet Printers
Pixma MX410 won't scan
My Canon Pixma MX410 multifunction printer all of a suddn won't scan from my laptop.  We can copy a document manually and print from my laptop but I get the messsage above.
jmartora by Apprentice
  • 1569 Views
Resolved! MX922 PGBK issue
Does anyone know what the PGBK prints like this? It will start to print like it should, then as the letters PGBK start to print on the test page, it opens up like the eye of a needle, then as it gets past the letters it closes back up to normal print...
apple2gs by Contributor
  • 5462 Views
  • 3 replies
IP 8750 misalignement problem.
Can anyone please tell me how I can remedy the double printing as seen in the PGBK column?  All other auto cleaning and reference strip cleaning has been done, ink nozzles removed and cleaned etc etc.  Hope you can help, many thanks, David
MX922 Error and possible actions
MX922 has error code 1403 which says "The Wrong Printer Head is installed".  I have reset the printer head twice with no change in the message.  Is there any option here?  Is buying a new printer head possible and  is it worth it...the printer is 5 y...
JonSH by Apprentice
  • 1022 Views
Pixma G4210 - Always Showing OFFLINE
All of sudden I can't get my Pixma G4210 to print or scan from or to my computer. It always says it is offline when I try to print and gets suck "Printing - Looking for printer" and can't connect. When I try to scan it can't connect either. I am usin...
Canon Pixma TR8620 Duplex Printing Malfunction
When I print a two-sided page, the printer prints two pieces of paper at the same time. On the front of the first page is Page 1, on the back of the second page is Page 2. It thinks the two pieces of paper are one sheet of paper. How do I fix?
lgp2021 by Apprentice
  • 1189 Views
PIXMA TS6350 Cannot get set up package to run
I’m having problems installing my new Canon TS 6350. When Running the driver set up package I get the following error:“Failed to acquire information on the driver and software.” My PC is running Windows 10 Pro.  I log on as  administrator.  And I tri...
pigasus by Apprentice
  • 1198 Views
  • 0 replies
MX492 - new port could not be created. : 0023
Hello, I have been reading the threads about cnmnpu.exe and also New port could not be created: 0000. However I was not able to solve the issue. I have removed all Canon software, run cnmnpu.exe and then SETUP64. I'm still getting the same issue "new...
pmcinen by Apprentice
  • 5209 Views
  • 2 likes
