03-24-2018 07:20 PM
Trying to help a friend out. They have a MX860 series. They put new black cartridges in, and they show full. Tried taking them out and shaking them and putting them back in. Did the duty cleanings. It will scan and send to the pc a picture correctly. Trying to copy just black is a blank page. Color will print. I am attaching a picture of the Nozzle check, which shows the black printing on the check. I have tried typing something in MS works, no luck. Almost seems it is trying to print white. Is there a setting somewhere I am missing? Is there a factory reset for the computer? Does not work any different from the computer or just using it as a copier. thanks Bruce
05-04-2018 12:18 PM
Hi brucefl56,
The nozzle check from your PIXMA MX860 should appear as below:
Please make sure that the larger black ink tank contains ink, replacing it as necessary.
Once that has been checked, please perform a few printhead cleanings:
1. Press the MENU button on your PIXMA MX860.
2. Select Maintenance then press the OK button.
3. Press <OK> to select Maintenance.
4. Select Deep Cleaning and press OK.
5. Press OK to select Yes.
The Deep cleaning will be performed. After 2 or 3 cleanings, print another test page.
The black grid should now print at the top of your nozzle check.
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
12-12-2020 01:25 PM
Those directions helped me out today. I had to perform the deep cleaning a couple of times and then it worked. Thanks so much!
