Desktop Inkjet Printers
PIXMA TS3420 won't pick up paper, colors are dull
Brand new printer will not pick up paper of any kind. And i did a comparison with this printer and epson with printing colors and i cant believe how dull looking images and stickers turned out when epson was so colorful and vibrant. And the settings ...
Allen81 by Apprentice
  • 590 Views
  • 2 replies
PIXMA G620 Duplex Printing on Mac
I just set up my PIXMA G620 printer after my MG7700 finally stopped functioning. Am I correct that this printer is not able to support duplex printing with the current Apple drivers? Duplex printing worked quite well from my MG7700, so I'm very surpr...
dlbrey77 by Apprentice
  • 2621 Views
  • 4 replies
Pixma G3200 Waste Ink Tube replacement
My Pixma G3200 megatank printer stopped picking up paper & after disassembling, I've found the waste ink pump mechanism has pulled the 2 tubes out of the ink absorbers and broke 1 in half. I am trying to find the right tubing to replace. Silicone tub...
PIXMA G3272 Not Connecting to Macbook
I have successfully setup and connected my printer to my phone, but have spent about two hours trying to connect this same printer to my Macbook Air only to repeatedly run into the same issue. Whilst running through Master Setup on my Macbook, the pr...
Canon Pixma TR4722 - Setting back up after moving
Hi folks, Frustrated "dragon slayer" here.  I bought the above-mentioned printer in November 2025 and installed it to my computer via wi-fi.  I've since moved to the other side of the country (south to north) and had to reinstall it again.  I've trie...
MarnieA by Apprentice
  • 597 Views
  • 2 replies
Resolved! PIXMA TR8622a touchscreen becomes unresponsive
The touch screen quits responding to touch after printer sits for awhile or after it powers down. Powering off and then back on does not fix the issue. I have discovered that you have to unplug the AC cord and then plug back in,, it seems to reset th...
Canon PIXMA g3410 not photocopying full page.
Help my canon g3410 cannot photocopy the full size A4 page. Works well with printing and scanning but always leaves a margin of about 2mm on the bottom of page when I use the buttons on the printer. Photocopy also works well when I use the phone app....
Kajih by Apprentice
  • 1531 Views
