I have a Samsung laptop,i cannot install my mx340 printer to it. it states that it is offline.
i need to install a mx340 printer to my laptop
My new cartridges are not lighting up and consequently I am getting the error code 1401. Please someone help me fix this issue. Thanks.
Hello, I have Windows XP. After a virus scan with AVG the Image Garden won't open anymore. If I click on it I get the message as shown in the image below. The same message is showing everytime at start-up. I read and tried the solution below but doe...
the device is connected directly via USB, when i try to use the scanner with scangear but there's an error message 5,157,69. Im using windows8. Already read the article scanner problem with MX5420. How can i fix this? Thank you
My 5100 series printer was replaced under guarantee for a new MX5204 printer after the older machine showed a B200 error.When I installed the new MX5204 it immediately also showed B200 error. Is there a software problem that can be reset or what coul...
If I photo copy there is no problem with the printer, only when I print from the computer it shadows. Why is this?
My MX882 started to print every fifth line very lightly or not at all. It has gotten worse so that maybe every fifth line is printed OK. This only happens when I print from my laptops (I have two). If I make a copy of a printed sheet at the copier, ...
Hello, I'm having trouble with my Mx922 printer. It begin the print, stop at half the page and then says printing complete.Does anyone know what this problem is?
Answer fro Canon please on U052
Can someone please assist with subject as above. I have followed the directions in the manual. Thanks.
Just got new computer with Window 8 64bit OS. Unable to find driver for CanoScan N650U.Scanner last worked ok on old computer running Windows XP.
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
