Desktop Inkjet Printers
MG3500 cannot comunicate with scanner
the device is connected directly via USB, when i try to use the scanner with scangear but there's an error message 5,157,69. Im using windows8. Already read the article scanner problem with MX5420. How can i fix this? Thank you
solasoli by Apprentice
  • 5259 Views
  • 0 replies
Brand new Canon MX5204 showing error message B200.
My 5100 series printer was replaced under guarantee for a new MX5204 printer after the older machine showed a B200 error.When I installed the new MX5204 it immediately also showed B200 error. Is there a software problem that can be reset or what coul...
microse by Apprentice
  • 4348 Views
  • 0 replies
shadowing
If I photo copy there is no problem with the printer, only when I print from the computer it shadows. Why is this?
tholmes by Apprentice
  • 4892 Views
  • 0 replies
MX882 printer not printing some lines
My MX882 started to print every fifth line very lightly or not at all.  It has gotten worse so that maybe every fifth line is printed OK. This only happens when I print from my laptops (I have two). If I make a copy of a printed sheet at the copier, ...
SteveM by Apprentice
  • 6597 Views
Canon MX870. The Paper is not 'gripping'
I'm having issues with the paper not 'gripping' and I keep getting an 'out of paper' message.  The only way to keep it running is to keep it full to the top and then it happens again after 10 prints.  Any suggestions?
csbucks1 by Apprentice
  • 5411 Views
