10-19-2024
11:42 AM
12:37 PM
The Geek Squad tried to get my printer working but didn't succeed and referred me to Canon. Is it possible to talk to a real technician?
10-19-2024 11:44 AM
Thanks for joining the conversation, Sycamore1!
So that the Community can help you better, please let us know what kind of problem you're experiencing with your PIXMA MG5420. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE.
Thanks and have a great day!
10-19-2024 11:51 AM
Printer is not working and I received an error message letting me know a printer error has occurred. The Geek Squad tried but failed to get the matter corrected.
10-19-2024 11:57 AM
If you could tell us what that error message said, that would really help us help you. We look forward to your reply!
10-19-2024 11:59 AM
The standard instructions to turn printer off and on. Same routine that I went through with the Geek Squad. The final message was to contact the service.
10-19-2024 12:32 PM
Are you still there?
10-22-2024 01:32 PM
Hi Sycamore1,
Please unplug the power cord from your PIXMA MG5420 for 15 minutes or so.
After that time has elapsed, please reconnect the power cord and turn your PIXMA MG5420 on.
What is the Support Code that appears on the display of your printer?
If a code does not appear, please attempt to print.
If you are unable to print, please look at the display of your printer. What is the Support Code that appears?
Did this answer your question? If so, please click the Accept as Solution button so that others may find the answer as well.
10-22-2024 06:52 PM
The support code that continues to come up suggest all of the things I've already done and then advises the user to check the manual or contact the service. I do not have a manual so I continue to contact the service.
