Desktop Inkjet Printers
PIXMA MX922 - All in One Scans slowly
I am using a MX922 All in One on a PC with Windows 11.  Previously it has worked fine.  For the past several months it has been scanning very slowly.  I did fix this once before with deleting and reinstalling the software but this is no longer workin...
rrfurman by Apprentice
  • 1801 Views
PIXMA TS3122 Scanner not working
The scanner function suddenly stopped working.  I am not getting an error message it just goes right to the part where the scan starts and flashes briefly.  I have the scanner/printer connected with USB to an EliteOne 705 HP computer running Windows ...
PIXMA iP110 - ink type
Could you tell me whether the #35 & #36 ink for the Pixma iP110 printer is dye-based or pigment-based?  I need to clean the ink housing & a different solution is required for the 2 ink types.
PIXMA G7020 Error message when I try to print
Hi,  I really need help!  I got this printer a couple weeks ago.  Setup went fine and I could print.  I have not tried to print in over a week and now I can't.  The printer is on, connected to WiFi.  It currently says "Copy" on the front dialogue pan...
KellyH by Apprentice
  • 1259 Views
PIXMA G7020 - printing thin lines
  Canon G7020, I’ve done cleaning, deep cleaning, refilled ink all the way, manually taken out the print heads and cleaned them carefully.  This issue just started after owning it after one year. I’ve always printed a lot so I don’t think it has to ...
Resolved! PIXMA MX882 Error B200
Printer MX882 which had been working fine for a few years.  Then bad printer head error appeared. Tried cleaning, flushing with no avail.  Ordered a new print head.  Installed and promply got an B200 error, which I have been trying to solve with solu...
thud413 by Apprentice
  • 115503 Views
  • 8 replies
  • 1 likes
Duplex Printing Paper Jam on TR4722 Printer
When trying to duplex print with my TR4722, the paper hangs up when the paper starts to flip. After printing the front of the page and the printer starts retrieving the page to flip it, that's when the hangup happens. The paper is then ejected and I ...
jerrydon by Apprentice
  • 1519 Views
PIXMA iP8720 Pin missing from ink cartridge slot
question about ip8720 printer repair ive had my ip8720 printer since about april of 2020, and she has served me so well. i was doing a big printing session about a week ago when i changed out one of the ink carts, and afterwards it stopped working. u...
PIXMA MX922 - Stopped Scanning
I have a Mac aligned to this MX922 series printer - printer purchased in June 2018/  The printer has worked great, however the scanner stopped working.  Although I just recently noticed the problem when I tried to scan a doc, it appears the issue mus...
PIXMA TR7451i stopped printing yellow
Canon TR7451i Printer (Windows 11) My printer has developed an "odd" fault. I use it mostly for printing all sorts of Cards. Up until a few days ago it was fine. Setting I used were: Print, Properties, Quick Set-Up, Greeting Card, Media: Inkjet Greet...
Resolved! Getting Error 5100 on PIXMA TR4722 printer
I recently put in new cartridges both color and b/w into my Pixma TR4722 Canon Printer.  I am getting Error 5501. I go into the cartridge area and pull them out one at a time and put them back in. I then turn the printer off for a few minutes and tur...
