Search instead for
Pixma TR8620 operation panel
rms59
The printer only operates with the operation panel pulled up until it's horizontal which really bugs me to no end and I'm still thinking of returning it for that reason. On the bottom of the panel there is a small plastic lever which operates a small switch that changes state depending on the position of the panel. When the panel is down the switch is in state 'A' and when it's up (horizontal) the switch is in state 'B'.
What would happen if I prevented the switch from changing to state 'A'. Would the printer still work? The reason I ask is that I would have to modify with a Xacto knife.
4 REPLIES 4
Patrick
Hi rms59,
You are correct, the operation panel must be opened in order to print with your PIXMA TR8620.
Making modifications to switches inside of the PIXMA TR8620 is not supported.
debmae2021
i am trying to set up a new tr8620. I keep getting support code 1240.  How do i open the Operation panel? Where is it? I need a visual HELP
It isn’t intuitively obvious.  I don’t like this feature.  Like my prior Canon MX922 Better.
debmae2021
I actually figured out my problem by reading about the horizontal issue.  Thanks
09/19/2022: New firmware version 1.0.4.1 is available for EOS C70
08/31/2022: New firmware version 1.1.1 is available forRF 70-200mm L IS USM
07/28/2022: New firmware version 1.2.1 is available for EOS-R3
07/21/2022: New firmware version 1.6.0 is available for EOS-R5
07/21/2022: New firmware version 1.6.0 is available for EOS-R6
07/21/2022: New firmware version 1.1.0 is available for EOS-R7
07/21/2022: New firmware version 1.1.0 is available for EOS-R10
07/01/2022: New firmware version 1.3.0 is available for PowerShot PICK
06/07/2022: New firmware version 1.0.3 is available for EOS M50 Mark II
04/26/2022: New firmware version 1.0.1.1 is available for EOS R5 C
02/07/2022: New firmware version 1.6.1 is available for EOS-1DX Mark III
01/05/2022: Welcome to CES 2022!
