Onedrive direct transfer option on EOS cameras?
@Canon are you planning to add onedrive as one option to transfer pictures from EOS Camera? Thanks
My R5 MK 2 works fine with my EF 16-35 f4 L and my EF 24-70 f2.8 L lenses, it also seems to work fine with my RF 28mm f2.8 STM lens. A couple of months ago, I purchased a RF 24mm f1.8 STM and found that, randomly, at camera turn on, both the EVF and ...
I accidentally dropped my m50 Mark ii, it was not too hard, the surface was carpet, the body it's ok but apparently the viewfinder moved, it still works tho you can see the image, take pictures and videos, but my lcd will not work. what should I do? ...
Hello, We're about to be grandparents and hope to help our daughter and son-in-law with an informal maternity shoot at their home tomorrow... The plan was to use a couple of high-end iPhones, but we moved up our plans to purchase a nice camera and p...
Hi I would like to report a bug revolving around the preview image of the Canon EOS R5 Mark II. I've noticed that there is no image for the EOS R5 Mark II. Every single image is gone. I don't think this is a bug just for me because all of the other p...
Hello, I have the Rebel T8i, and I’ve just upgraded my lighting and I feel like my camera still isn’t picking up the lighting. I’m getting into beauty videos for YouTube. Can anyone recommend settings I should try that’ll help? Thank you
My EOS R10 suddenly started acting like I’m half pressed on the shutter button. However, my finger is not on it. I have a button to go from Servo to One Shot focus but no matter which one I set it to, the focus box instantly goes blue or green and wi...
Hi,I have used the Canon R1 and R5 Mark II for several weeks to photograph sports. Both cameras seem to have the same problem for me, and I am looking to see if others have had issues as well.When using the R1 or R5II with the 100-300 f2.8 or 24-105...
I haven’t been able to find an answer for this. My new R5 Mii will record audio at 120 fps now which is great. But I don’t understand how audio works. Obviously it records at the higher frame rate, but the audio slows when played back, say, on a slow...
I have had my t8i for a while now and I've had no issues with it till now when I'm trying to capture pictures of this massive lightning storm. Made sure my card was formatted and now my controls are locked. I can't get to the menu or operate my camer...
My Canon 80D has been a fantastic camera for 5-6 years however recently I can no longer turn the mode selection to AV or TV shooting modes. I have tried multiple lenses so I believe the problem is at the camera. Any advice?
Greetings,After 11.5 years and many thousands of photographs with my trusted Canon EOS 70D camera which I purchased new, a diagonal black stripe started to appear across every photograph with a white strip at the bottom.I took off the lens and lifted...
Hello,I was using my Canon camera today as a webcam, connected to a MacBook via the USB cable, when it suddenly froze up (showing the last frame it captured in the LCD screen), then I turned it off.I replaced the batteries, tried a direct current cab...
Checking the EXIF on images from my Canon R5 there doesn't seem to be a value for 'LightSource'. Just wanted to check this is correct, and if there is an alternative, e.g. if the same value is now stored somewhere in the makernotes instead?
R6Markii Autofocus touch and drag function works on screen, but not through viewfinder. I use the little white square on the back screen and its perfect. But I look through the viewfinder, the square is there, but it NEVER focuses. Have I missed som...
| Subject | Author | Posted |
| 09-20-2026 03:10 PM | ||
| 09-09-2026 07:25 PM | ||
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-22-2026 11:08 AM |
