Canon PIXMA TS5150 - scan from ADF
Hi,There is a way to scan from ADF (paper feeder) from MacOs or iPhone?I have canon ij scan utility on my macos but I can't change the scan source.Screen Shot 2022-04-03 at 0.22.02.png
I wanted to try the printer with only black ink installed on first use. Will the printer work this way out of the box before dumping the color ink in the tanks? It is giving me an error that I cannot get by. If so does that mean that if the clor runs...
I want to print 4x6" mailing labels from a roll (ie. one that would go on a mailing label-specific printer such as 4xl) on my Canon Pixma mg8120. Is this possible?
I have a TR4522 and I need helphow can I change from letters to numbers to symbols??
Hello and Help! I have a TX6420 and the pages ARE NOT PRINTING! I've done everything, gone to Youtube, gone to the support page, read everything about pages not printing. I checked the maintenance, the printer preferences, the ink is high. Pleas...
I am getting an error code (E03) for a paper jamb but there is no paper in the printer. Paper can be fed through when the printer is first turned on but after that the printer will not feed itself to start printing. Tried unplugging for 30 mins and p...
Hello - i just purchased a Canon Pixma TS6420 printer and set it up wirelessly since it does not come with a USB cable. The printer function is working fine after the normal driver install, but the scanner will not recognize. I have tried finding it...
This started a few days ago and I have not figured out what is going on. I originally believed it was Powerpoint causing it, however, the issue does not go away when I covert to a PDF. Image shows what i see in print-preview versus what actually come...
My printer started printing blank pages in the middle of a print job this morning. I have done all the cleanings I think and I am still coming up with blank pages. Any ideas? Ink cartridges are full...
While setting up my new printer I entered the wrong language. So I need help fixing this. I need to change the language from German to English. Can anyone tell me how to do this?
I need help sending and receiving a fax, also correcting the Tim and date on the fax machine. It is a Pixma MX922
Hi, My black (PGBK) was not printing. So tried to clean the print head, but I could not get it to come back. So I bought another printhead, and this new one prints the black pattern and text with a shadow. The test print looks like this (attached). T...
I printed out a picture one day and it came out beautiful in color five to six hours later I tried to print out something ells and all it would do is print out blank pages all the ink cartridges are practically full as I recently had changed them I c...
Hello, we have a Canon TR4520 and the other day it decided to stop receiving and sending faxes to two numbers. Just these two numbers, it works with ever other number. If you call it the fax picks up but when it tries to send a fax to these numbers i...
Is this printer compatible with 5.0 gH wifi?Thanks
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
