Desktop Inkjet Printers
Pixma mg2540s compatible cartridges
I have a Pixma MG2540s printer which seems to be a non-us model.  I am currently in the U.S. & my question to you all, is what would be the compatible cartridge for the printer that I can use right away?  [for your info, I plan on buying the cartridg...
kuh by Apprentice
  • 1746 Views
Resolved! MX310 SCANNER not found on Windows 10
MX310 printer/scanner worked fine but now with latest update to Windows 10, the printer still works fine but Windows 10 does not see the scanner at all, so cannot scan. How can I get Windows 10 to see the printer?
cam0805 by Apprentice
  • 13448 Views
  • 3 replies
Cyan won't print on our MX920
We can't get the Cyan to print.  A test print shows that those bars are missing and we have deep cleaned 3 times and replaced the cartridge with a new one.  Is there anything we can do?
DBob by Contributor
  • 1005 Views
Pixma MG-3620 image has a large VERTICAL white gap.
HELP!!  My print quality has gone down the toilet.  My PIXMA MG-3620 has started double-printing (looks like a ghost image), cutting off the left edge, and there is a large VERTICAL gap in both the black and color printing.  I cleaned everything more...
sarako by Apprentice
  • 1334 Views
Canon Pixma G3260 Printing photos with red hue
Hello there! I just bought a brand new Canon Pixma G3260 and I love everything about this printer except the fact that all my photos have a red hue to them if I print using the photo paper setting. If I print on regular paper, there is no red hue.I d...
codejo by Apprentice
  • 2244 Views
  • 2 replies
Continuous paper jam
I am trying my hardest of fix this issue without sending the printer in for repairs. The paper will get pulled into the printer when it starts to print then gets stuck. I will remove it from the flap in the back. I have done the alignments and that d...
Print stuck in queue after reboot....
Hello,I just installed a PIXMA TS 3350 printer on a new computer with Windows 11.Everything works fine.I installed the canon driver for Windows 11, plugged the printer (in USB). The printer is recognized and works. I can print.But after a computer re...
ICC profiles for Canon Pixma iP8700
HELP please!!! I recently purchased a Canon Pixma iP8700.  I use a digital design program Silhouette to desing and print images.  The colors are SO OFF!!!  I have a pink and purple pattern that is printing red and blue.I have other printers that prin...
PIXMA TR7020 Broken Printer
Hello I had contacted you on 5/23/2022 regarding a printer we purchased from you. we were told the replacement would arrive in 2 couple days and for us to simply return the broken printer to you in the same box. since it was under warranty. We have s...
curtis1 by Apprentice
  • 1215 Views
Printer Canon PIXMA MX310
Hello:I am wondering if the PIXMA MX310 is still in use with more recent OS of Windows and Mac? Is the firmware updated or has drivers to make it compatible?  Thanks
melmorsy by Apprentice
  • 2738 Views
  • 4 replies
MG7120 disabled by firmware 4.060
My white Canon MG7120 has been a joy to use, fast reliable, and nearly flawless. And then firmware 4.060 updated and ruined my sanity. Ive tried hundreds of pages and I cannot get a single page to print or copy correctly. Unless you print the nozzle ...
MG3022 Cuts off End of Page When Photocopying
I've recently bought a second hand MG3022 and set it up fine. But when it comes to photocopying, when you print from the flatbed scanner, I've noticed that the bottom few millimeters of the page is always cut off. I'm printing normal letter paper (8....
print-ea by Apprentice
  • 1647 Views
