Mp600 only half line will print
The top half of lettering prints
I am having problems finding out where the waste ink pad or pads are for the G6000.I have done an ink flush and want to make sure the pad(s) are not saturated.
I have a pixma 922, the black nozzle check is coming out black and gray. The pritining reflects that, black text comes out gray and black, it appears that one size of the nozzle head is not working. I tried nozzle alignment, cleaning, deep cleaning, ...
My Mac running High Sierra has both the print and scan options for my Pixma MX532 but my Mac I just purchased that is running Big Sur can only print. After I 'added' my MX532 from the Printers & Scanners and selected the printer I do not see the pri...
I am having trouble with printing color on my TS 9020 inkjet printer. The cartridges all contain ink - there are no low level warnings. I have tried cleaning the printhead and deep cleaning the printhead (several times in fact). However, except for y...
Suddenly my printer doesn't seem to connect with computer to print.I get message " Printing - the printer is in use" with the name of the doc, but just get a blue line moving back and forth on the printer status and no doc printing. Help!I'm using a ...
I can not figure out how to submit a new question, so I am tagging onto this one.My Pixma G4210 prints only in green.I have filled the ink tanks with Canon inkI have deep cleaned twice.It stays green, even when trying to print documents in black.Phot...
I've tried the usual cleaning utilities but nothing has helped, including the Q-tip suggestion related to Bottom Plate Cleaning (and the hair marks are on the printed side, not the back of the paper). There must be a way to find and remove whatever i...
Hello,When I print a document to the Pixma MG5320, one of the Printer Features is called DuplexSurface.The choices for this setting are zero and 1, with a default of zero.What is it? What does it do? And when would I set it to 1?Zero is the amount of...
Hello, I have a new MG3620 printer and it worked okay for a few days. Now when I try to print using the color (even if its black and white) the print comes out all distorted. If I click just use black, its better but not 100%. I have cleaned the h...
It prints fine from the computer over wifi. When I scan the scanner runs but then gives the error that it can't connect to the computer.
Ink tanks are 3/4 full but Cyan and Yellow will not print. Did cleaning and tried to do deep clean but getting ec 5200. Ink flush didn't help as both issues still exist. Printer purchased 5/19/2021.
What is the difference between the Pixma TS702 and the Pixma TS702a?
Hi, new to art print and a bit confused about what archival paper goes with it.Looked into a few paper options from best paper for art print list, all thicker than the allowed 200 g /m2Found some photo papers that goes with it, such as red river. is ...
| Subject | Author | Posted |
| 09-20-2026 05:36 PM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
