I can not figure out how to submit a new question, so I am tagging onto this one.My Pixma G4210 prints only in green.I have filled the ink tanks with Canon inkI have deep cleaned twice.It stays green, even when trying to print documents in black.Phot...
I've tried the usual cleaning utilities but nothing has helped, including the Q-tip suggestion related to Bottom Plate Cleaning (and the hair marks are on the printed side, not the back of the paper). There must be a way to find and remove whatever i...
Hello,When I print a document to the Pixma MG5320, one of the Printer Features is called DuplexSurface.The choices for this setting are zero and 1, with a default of zero.What is it? What does it do? And when would I set it to 1?Zero is the amount of...
Hello, I have a new MG3620 printer and it worked okay for a few days. Now when I try to print using the color (even if its black and white) the print comes out all distorted. If I click just use black, its better but not 100%. I have cleaned the h...
It prints fine from the computer over wifi. When I scan the scanner runs but then gives the error that it can't connect to the computer.
Ink tanks are 3/4 full but Cyan and Yellow will not print. Did cleaning and tried to do deep clean but getting ec 5200. Ink flush didn't help as both issues still exist. Printer purchased 5/19/2021.
What is the difference between the Pixma TS702 and the Pixma TS702a?
Hi, new to art print and a bit confused about what archival paper goes with it.Looked into a few paper options from best paper for art print list, all thicker than the allowed 200 g /m2Found some photo papers that goes with it, such as red river. is ...
Hello all --I have not had any success resetting my MG2220 using the various schemes on the internet. I'm hoping this community will bear fruit.Thanks in advance for your help. Otherwise, I will soon be using another manufacturer's printer.
I had an streaks across my initial print. Went to clean nozzle settings to elimate the issue. After nozzle clean I tried to reprint the article and now I am getting red print only . Retried nozzle clean again with no luck. HELP!
Hi, -------------EDIT-------------So, some of you may have been thinking "try a Canon cartridge!" -- well, I did just that, and the error has cleared. I suspect, but cannot be certain, that I replaced the last of the Canon cartridges at the same ti...
I have a Canon Pixma G7020 printer. Very strange behavior of the Deep cleaning function. Every time I am pressing Deep Cleaning (All Colors - BK, C, M, Y), error 5200 occurs. The green and orange lights blink 8 times. There are no unnecessary object...
My printer has been sporadically not printing (have power, connections ok, ink cartridges full); paper comes out blank. Now it has stopped printing completely, only blank sheets come out. I re-seated the print head, that made no difference. Everythin...
I bought a Canon G1200 Pixma printer a while back and while I usually just print black & white documents, I print a few things in color maybe a few times a month. When printing any color graphic I often get poor color reproduction, and almost always ...
| Subject | Author | Posted |
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM |
