Desktop Inkjet Printers
mg3570 won't let me access printer settings
tried setting up my canon printer to be used on my google chromebook. it worked once upon a time then stopped! anyways, i thought maybe i needed to add a password, so i did that in the user authentication setting. now it won't let me access the print...
ocdguru by Apprentice
  • 5013 Views
  • 3 replies
mx922 confused- pc and mac environmant
mx922 installation was difficult.    set up the pc - ok - can print and scan.    set up the mac- had to fight with it- then 3 hours later just posp up.   can print from mac, not from pc. reset printer - can print ffrom pc- not from mac. rest again- s...
MG5320 error message "Printer head is incorrect"
I just installed a new cannon print head and the same error message is coming up even after replacing with a brand new print head and unplugging for more than 15 minutes... This seams to be a built-in defect with so many people having the same issue....
Murphma by Apprentice
  • 3616 Views
Resolved! mg5400 does not scan. will not print remotely
I have an mg5400 which I really like and has served me trouble free until recently.  it now longer communicates wirelessly.  it must be hard wired to accept a print command.  says printer is offline even though it is up and running.  takes right off ...
wascals by Apprentice
  • 9516 Views
  • 4 replies
MX882 freezeup
My MX882, after sitting for a while, will always freeze up, so that when I go to print, it doesn't respond, and all the buttons are dead. To add insult to injury, after pulling the plug and restarting it (apparently my only options), after starting u...
IP3500
My IP3500 worked fine for years until a few days ago.  It will only print graphics but will not priot any text.  What could be causing this?
mamarose by Apprentice
  • 4033 Views
  • 3 replies
PIXMA MG7120 Firmware 4.04 warning
Firmware upgrade will cause printer crashes.  Printer randomly powers down.  On power up given caution "Power was not turned off corectly the lat time.  Press the (O) button when turning power off." Have discussed with 2nd level tech support at Canon...
tbrass by Apprentice
  • 7173 Views
  • 6 replies
