Desktop Inkjet Printers
Pixma MG3520
I am having problems of trying to get my printer recongized on my laptop. I lost the cd that came with the printer due to moving. I had to use the drivers onlune to download. I used the scanner once and worked fine. Now it has the error message that ...
MG5522 scanning a document
I can't figure out how to scan a document using the scan button on the printer and have it go directly to my document folder on my pc. I press the ok button and it says auto scan and i press  the black button and it just says processing, please wait ...
MX922 won't print from USB
Hi,I'm trying to print a 1.2MB PDF file from my MX922printer via the front USB port from a microUSB card in a usb card reader. It reads my documents, photos, and my PDF files, then asks which I want to print. I chose documents, and keep getting :Erro...
CelticZ by Apprentice
  • 6643 Views
  • 2 replies
Paper size doesn't match
MG5520 will not print my 8x11 wafer paper. I have tried it the letter size setting and A4 setting. It pulls the paper through but doesn't print. Gives an error message that paper detected is not same size as settings. I have turned off auto paper siz...
support code 1007
I keep getting the support code/error 1007: no paper in upper tray I am just trying to print reading passage on different websites. The printer sounds like it is trying to do something. Pleae help!
grove09 by Apprentice
  • 3447 Views
MX892 COLORS ARE OFF
My MX892 no longer prints accurate colors.  For example, I print something thats green and the printer puts it out in blue.The ink tanks are all full, and in their proper location.  Any ideas?
tntmoul by Apprentice
  • 3600 Views
  • 2 replies
Getting Max Res Scans/Prints on Pixma MX922
I just got a Canon Pixma MX922 All-In-One printer/scanner and am trying to do high res scans and prints.The bundled software and on-screen menu options top out at 600dpi, but the unit is advertised to have much higher capability. Is there something I...
Pixma MG5320 use color ink in B&W mode
Hi, I have a little question for you. I have one Canon Pixma MG5320 since few years and I don't need to print a lot with it. But, today, I had to print a 100 pages document in Black & white and I was supprised that two colors ink cadridge been used t...
