I am on windows 7 if I upgrade to windows 10 will my MG5250 printer work
Currently on windows 7 but want to upgrade to 10 but will my MG5250 printer still work?
I have a Pixma MP970. Will it function on the new Windows 10 coming out in a few weeks? Also, what setting should I use to print on vellum?
Hi, I have the above printer on Windows Vista and I was printing photos just fine until one day I was not. The photo prints and the ink is not clear at all, it almost looks like an old fashioned negative and the ink does not dry. I left one sit f...
I have a Canon Pixma MG2520. I use it to print individual checks by inserting them one by one or a sheet of three. The printer is hit or miss with if it prints the check without printing crooked or the lines way off. Any tips?
I am trying to scan from my MX922 printer and I just get the message "set the pc to start scanning" I am using windows 10 operating system.
After upgrading from W7 to W10 the scanning on my MX410 has become slow and choppy. I have uninstalled and reinstalled the software and have upgraded the drivers. My printing works fine.
I've done a roller cleaning and checked for obstructions. The rollers don't seem to be able to catch the smaller size paper. It used to but just stopped. If I push the paper in, it will catch but then just spits it out without printing.
I'm new to Canon printers and just set up the above printer. Is there a tutorial available for printing greeting cards? Thanks! David
My IMac recognizes my CanonMG2520 printer, scanner copier but there is a yellow blinking light belowthe power button & it won't print. Can someone help. Thanks in advance.
I have a Canon Pixma 5520. When printing in black ink, I noticed that the ink was printing only parts of the document. It had the appearance as if someone tried to move the paper while it was going through the roller (part of the letters printed and ...
I haven't used my scanner on the printer until recently. It does scan, and I save as .pdf document on a flash drive. But it doesn't scan very dark. It is sometimes impossible to read or see what I've scanned. Anyone else have this issue? Wonderi...
My new printer is connected wirelessly to our two Windows 10-using computers. When asked to print a document, it sits there making whirring and clicking noises for three minutes, then finally starts printing the last page of the document, pauses half...
Canon i850 printer. I replaced the waste inkpads and now it will not power on. What do I do? Is there a reset button or could I have knocked something loose inside? Is there a fuse inside? If I remove the plastic case again, is there any reason ...
| Subject | Author | Posted |
| 09-05-2026 10:28 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
