OSX 10.11.6 El Cap My Canon Pro 9500 Mk2 is not recognized . Have tried different parts, no response
Osx 10.11.6 Canon Pro 9500MK2 printer is not recognized. What am I doing wrong?
Hi friends, I have plenty of documents to print and I want my printer to use the Black Ink to print the black and white documents, instead of producing black color by mixing the cyan, yellow and majenta colors. How can I make my prin...
Hi, I just bought a new MG 6750 printer which was sold as coming with a full set of inks (I went for this one at slightly more expense specifically as others came with setup inks only). The inks I received have "setup" writton on the packaging tho. ...
Hi there I was wondering how do I do T-shirt transfer printing with my MG2420 ?? Or Mirror printing.Thanks in advance
I need to scan my **bleep**, but want the image to be larger so they can read the info on it, not the entire size of the page,but larger than the original size of my license, is there a way to have the scanned image larger than the original?
Have recently bought canon printer mx475 (2 days ago) and have had trouble printing from day 1. Printer is connected to router (after having to input passcode manually) and connectivity is 83%. I have had to delete printer off imac and try to reinsta...
Does anyone have an MG6450 printer? The paper feed was always tricky but now the paper won't go in the last quarter inch. Looking at it underneath it seems to be prevented by a spring loaded white mechanism which looks as if it is meant to be there -...
I have a document that I want to copy and make darker - how do I do it?
Hi all, A few days ago I bought a Canon Pixma MG7550, mainly to print photo's and printable discs.I have tried to print printable discs via My Image Garden and CD-Labelprint (older software that I used in the past with my Pixma IP4000 printer). Howev...
How do i fix error message E2 on my pixma mp 250 printer
My printer has worked perfectly for years. Now I get an error message when I try to print from the computer. Says it isn't connected to the computer. The cable is in place. I removed it and put it back in. I recently changed modems. Could this be an ...
My dear old HP959C has died after only 15 years of use, so I've recently bought a Canon Pixma MG5750. I would've preferred a stand-alone printer, as I have Canon 5600F scanner which has given sterling service for at least six years. I've installed ...
I thoroughly cleaned the print head on my F30 because it was not printing. It was copying and printing fine and then I used it to scan... Stopped copying and printing. It still won't print.
I have my printer conected via magic Jack. I share the line with my home phone. I am able to send faxes but not receiving faxes. Canon tech support have no solution or they can't guide me . Help !!!
When I use the Canon MG2520 quick or main menu to scan an image, whether automatically or document or picture or custom, it prints out the scan, even though I don't want it to do so. Fortunately, I can hit the printer's "stop" button, but, obviously,...
| Subject | Author | Posted |
| 09-05-2026 10:28 AM | ||
| 08-23-2026 08:30 PM | ||
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM |
