how do I convert mov videos to wmv
How do I convert mov videos to wmv? I can not find any free software to do this that is really free?
My Powershot is an ELPH 350HS.
Hello,New G7X Mk II user and first time poster with a question on using a slave flash with the G7X. Specifically, the camera came with a Vivitar SF-3000, which appears to fire correctly, but over exposes the shot.Should the G7X be adjusting the expos...
Hello: I'm really new to cameras and I just purchased a PowerShot SX720HS. I will be going to another country and I want to be able to take pictures and have them go to my windows 10 laptop. Can anyone help me get started on this? I'm very confuse...
Whenever my camera is moved it makes a noise that I can hear if I put my ear close to the camera. The internal mic is also picking it up making the audio in the videos unpleasant. The camera started occasionally doing this about 8 months but now it'...
I gave a search and either the wording was wrong on my part or user error! I just got a XS 730 HS powershot. Our first iphone paired without a hitch, but have been unable for it to pair or recognize the second iphone. Is paring more than one not poss...
Hello, I just bought the G7x II and can't figure out why I have this problem: In all modes (C, M, Av, Tv, P, A, Auto and SCN), I can zoom from 24mm to 100mm.Once I switch to "Movie" mode (the little camera icon between SCN and C), The G7x II automati...
SX60 turns itself on then sticks at either the busy screen, or if I remove the sd card then the "no memory card" screen.
I searched but couldn't find this topic. When I take a picture with my camera, the viewfinder goes black and none of the buttons work. I can't even power off the camera. The only thing that makes a difference is taking out the battery. I've tried 3 d...
To Whom It May Concern: My name is Andrew Wissler. I have a Canon PowerShot SX620 HS camera, and would like to connect it wirelessly for live streams through my PC and wireless network. I know how to connect my camera to the wireless network to downl...
I just bought a new Elph 360 HS. No matter what I try I can't set up wireless settings. It keeps saying Check Network Settings. I read that there may be problems on Canon's end. Does this happen often? At this point, I'm ready to return the came...
My PowerShot SX530 HS doesn't let me look at the pictures I've taken. I've tried charging it, switching SD cards, but nothing has worked. When I press the play back button, the camera just turns off.
Our QC person got a new Windows 10 Pro desktop, he had a temporary Windows 10 Pro laptop. His Powershot SX620HS worked fine on it. He got a new Windows 10 Pro desktop computer with a TP-Link AC1200 Wireless PCI Express adapter. The wireless card conn...
For some apparent reason, after connecting thru Wifi, my Powershot SX530 HS won't stay connected to Camera Connect app in order to download pictures or take pictures. After a few seconds, it will disconnect me. I'm using an Iphone 7 Plus with IOS 1...
I have a Powershot SX620 HS. If you are tranferring images via wifi and you are using a different wifi connection (traveling for example), do you have to manually change the wifi network settings (switch network) every time? Ugh
| Subject | Author | Posted |
| 08-19-2026 04:40 AM | ||
| 05-22-2026 11:35 AM | ||
| 04-23-2026 08:44 PM | ||
| 04-13-2026 11:03 AM | ||
| 04-08-2026 04:12 PM |
