EOS DSLR & Mirrorless Cameras
R5 Mark II Waveform!
How amazing they added waveform to this camera but I can't believe it can't be resized or disabled via an assignable button. To make things worse, it's multiple clicks deep into the menu to turn it off when you're tired of having it block your view. ...
gcam by • Apprentice
  • 5821 Views
  • 6 replies
EOS Rebel T6 won't power on
Little used Canon T6 Rebel/1300d camera, never wet/dropped. Will not power up at all. But will power on when battery/SD Card/lens are removed then put back in after at least 24 hours. Has had a new Canon SD card/Battery/lens, but problem is the same....
gopekto2 by • Apprentice
  • 1379 Views
  • 2 replies
Resolved! (How?) R5m2 autofocus standby
Hello! Maybe someone can help me to set autofocus of my R5m2 to work ONLY WHEN AF-ON BUTTON IS HELD, like it worked on my previous 6Dm2 (including Live-View mode). The problem that R5m2 autofocus is working constantly, even when none buttons is press...
Canon EOS 550D Freezes
my camera sometimes freezes and then can't be turned off. then i remove the battery and then it won't turn oni tried many ways like selecting into the P mode and then holding the shutter button for 15 sec and still doesnt work.the only thing that wor...
Alno2009 by • Apprentice
  • 1317 Views
EOS R8 - LCD Monitor issues
What started as a sporadic failure - now seem to be constant. Other functionalities of the camera are ok. There are no issues with the viewfinder.The touch capabilities are also fine - but the display is corrupted.
AlonT by • Contributor
  • 16572 Views
  • 17 replies
  • 2 likes
Canon EOS Rebel t5i firmware update corrupt?
Hello all, hoping someone can assist. I have a Canon EOS Rebel t5i which has always worked very well. I’ve owned since new for over a decade. I recently tried using the camera as a webcam and ran into issues with the software. I see there was a firmw...
MFM by • Apprentice
  • 1467 Views
  • 0 replies
Resolved! denying repair of r6 mkii within warranty period
I am writing to express my profound disappointment regarding the service I received for my Canon EOS R6 Mark II camera, which was purchased within the United States from a store in Anaheim, California. This camera was still under its one-year warrant...
jvh by • Apprentice
  • 6063 Views
  • 8 replies
