EOS 5D Mark III Mode dial wont turn
I just got a 5d mark 3 and then the mode dial wont turn. Idk what's wrong with it. Im still pretty new to this. Any help would be appreciated!
Hi all I can't get the small white box OFF my video screen. Closest info I could find said something about face detection. I don't want my camera in Manual Mode. I will appreciate ANY HELP.
Hello, I use the EOS M50 with its 15-45mm kit lens, and I've always had an issue with the photos not being very sharp or focussed in situations where the lighting isn't perfect and the subject isn't close. I have attached a reference photo which show...
How amazing they added waveform to this camera but I can't believe it can't be resized or disabled via an assignable button. To make things worse, it's multiple clicks deep into the menu to turn it off when you're tired of having it block your view. ...
Little used Canon T6 Rebel/1300d camera, never wet/dropped. Will not power up at all. But will power on when battery/SD Card/lens are removed then put back in after at least 24 hours. Has had a new Canon SD card/Battery/lens, but problem is the same....
Hello! Maybe someone can help me to set autofocus of my R5m2 to work ONLY WHEN AF-ON BUTTON IS HELD, like it worked on my previous 6Dm2 (including Live-View mode). The problem that R5m2 autofocus is working constantly, even when none buttons is press...
I have been a portrait photographer most of my 30 year career, but recently started sports photography and did a marathon yesterday. Used my R6 (M1) with EF 70-200mm f/2.8L IS II USM and adapter. I was in Tv mode, AI focus human eye detection with ba...
my camera sometimes freezes and then can't be turned off. then i remove the battery and then it won't turn oni tried many ways like selecting into the P mode and then holding the shutter button for 15 sec and still doesnt work.the only thing that wor...
We've moved this post to the Gear Guide forum.
My R5 keeps switiching video record quality from 4k-D to FHD. Is there a way to lock this setting so it can't be changed? Im using a custom mode so it really shouldn't be changing when I turn the camera on/ off.It's happening while in an underwater h...
What started as a sporadic failure - now seem to be constant. Other functionalities of the camera are ok. There are no issues with the viewfinder.unnamed.jpgThe touch capabilities are also fine - but the display is corrupted.
Hi All I’m looking for a way to upload photos from a Cannon dslr with WiFi or Bluetooth directly in real time into Apple’s photo app on a iPad/iPhone. Thank you
I've used Canon cameras for over 20 years without issues. However, my Canon 6D now only works in automatic mode. In manual settings, the shutter fails to respond correctly and stays open for 5 to 10 seconds before closing. I've reset the camera to fa...
Hello all, hoping someone can assist. I have a Canon EOS Rebel t5i which has always worked very well. I’ve owned since new for over a decade. I recently tried using the camera as a webcam and ran into issues with the software. I see there was a firmw...
Greetings Do you own an EOS R7 and use it daily?Have you updated the firmware to 1.6.0 without any issues?Do you recommend this camera for birds and wildlife photography?Thank you in advance.#EOS R7
| Subject | Author | Posted |
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-24-2026 10:39 AM | ||
| 04-22-2026 11:08 AM | ||
| 12-18-2025 01:20 PM |
