Desktop Inkjet Printers
Resolved! error 5100
Just purchased a  MG 3520 and run  maybe 10 sheets of paper then  a paper jam, it appears I am looking at a 5100 error. removed the  jammed sheet and  it all came out but nothing  will fix the error code. I have owned many printers, none that have qu...
Alarm Lamp lit on MG5520
Good Evening, I have a Canon MG5520 printer.  While I was out of town, the Electric Company replaced my meter.  My printer has been off for well over a week.  I do have it plugged into a surge protector.  The surge protector is still working.  My pri...
KimT by Apprentice
  • 2550 Views
Resolved! Pixma 922 stuck in 2 sided mode
I have a Pixma 922 that is stuck in 2 sided mode.  I am able to change this for a single copy using "Printer setting", but it immediately reverts back to 2 sided. I have my original on the scanner surface, and hit the "copy" buttons on the right and ...
PIXMA MX 459 Error Code B200
Hello All I'm new to the group and have a questions some have probably seen a few times. I can't seem to locate info on it. My PIXMA MX459 has 2 brand new Canon cartridges in it as of this morning.  For the first time since owning this printer I rece...
Resolved! Can't print from QuickBooks Pro 2017 to MX722
When I attempt to print from Quickbooks Pro 2017, all I get is a blank page. Sometimes it may print after I turn it off and on.It worked fine about two months ago and then all of a sudden it would not print. I can hear it going thru the motions like ...
Ken4 by Apprentice
  • 4048 Views
  • 2 replies
Resolved! MX434 scanning with shadow
I have an MX434 that is having issues with feeder scanning. The output shows a grey, shadowing line across the page. I have cleaned the scanning glass, rollers and what nots. But it still appears. I have a feeling its the rollers which are sort of "s...
example.pdf
Morello by Apprentice
  • 3072 Views
PIXMA MG2522 PRINTS DIFF COLOR
I thought that maybe changing colored cartridge might solve my problem BUT it was useless. still, I got the same problem, magenta prints red and the cyan has lines on it and fading color. The yellow and black inks are fine. Help me Guys!!
