06-15-2016 12:50 PM
Need help with B200 error code on Pixma MX922
06-17-2016 12:37 PM
Hi JPR,
It is recommended that you contact live technical support . There is NO charge for this call. Real time feedback of a live technical support call would be very beneficial in this case.
Please dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays). A Canon technical support representative will be able to resolve this issue faster.
11-02-2016 02:11 PM
The easiest way to fix this error is to open the printer as if you were going to change ink, wait for the cartridges to move past the half way point around 3/4 across and simply shut the lid. This works every time for me, although it may take a few tries. The method described in this video did not work for me and it takes a while-this method is much easier and after you complete this simple technique, a person will then have control of the printer and can do whatever type of maintenance they would like-it gives you your printer back
