06-19-2016 10:53 AM
Hello,
Since yesterday I have a problem with my Canon MX925 printer.
I see Error Code B200.
Can enyone help me about this issue? Has anybody faced and solved this issue?
Thanks
11-02-2016 02:10 PM
The easiest way to fix this error is to open the printer as if you were going to change ink, wait for the cartridges to move past the half way point around 3/4 across and simply shut the lid. This works every time for me, although it may take a few tries. The method described in this video did not work for me and it takes a while-this method is much easier and after you complete this simple technique, a person will then have control of the printer and can do whatever type of maintenance they would like-it gives you your printer back
